363 CI SBF Dart Block **TRADES**
1989 Ford Mustang LX Coupe BODY
Clear Title
Motor:
363 Cubic Inch Small Block Ford
10:1 Compression
Dart Iron Eagle Block 8.2 Deck 4.125 Bore
3.400 Scat 4340 Crank 28oz balance
5.400 Eagle H Beam Rods
JE Custom Pistons w/ 10cc Inverted Dome
Custom Comp Cams Roller Cam
Duration: 236/244@.050 290/304@.020
Lift: .608/.613 112 Lobe Seperattion
Heavily Ported Canfield 197cc Heads by Ford Performance Solutions
2.05 Intake & 1.60 Exhaust
Exhaust Runners Ported to 1 3/4 Headers
Intake Ported to a Fel Pro 1262 gasket
Comp Pro Magnum Rocker Arms 1.6 ratio
Comp Cams Hardened Pushrods
Comp Cams Double Valve Springs
Titanium Retainers & Locks
All ARP Pro Series Bolts
Canton Oil Pan
MSD Pro Billet Distributor
Edelbrock Victor Jr. Intake
Polished Aluminum Valve Covers
Extra Parts:
NEW QAI Tubular K Member
NEW UPR Tubular A Arms
Griffin Aluminum Radiator
NEW NOS Pro Shot 2 Stage Kit
Aluminum Driveshaft W/ the Big Joints
NEW UPR Pro Race Solid Upper Control Arms
NEW UPR Pro Race Solid Lower Control Arms
QA1 12 Way Coil Over Struts
NEW Strange 10 Way Rear Shocks
QA1 Caster Camber Plates
NEW Manual Rack
NEW UPR Coil Over Springs 175#
NEW 2 BG Fuel Pressure Regulators
NEW UPR Sepherical Bushings
I will sacrifice this motor for $7,000 obo. There is over $10,000 in it alone. If someone wants the Mustang parts, I will sell them all for $2000 or if someone wants both, I will make a package price of $8,000 including the car. I am also open to pretty much any trade, I dont have anything in mind so just let me know what you've got. I dont want to split up the parts unless the motor sells.
You can call me at 1-662-321-0758. If no answer, please leave a message.
Clear Title
Motor:
10:1 Compression
Canton Oil Pan
Extra Parts:
NEW Manual Rack
Matt's 95 Stang
10-05-2015 07:16 AM
