keyless entry lock beeping twice issue.
Old Mar 1, 2006 | 11:13 PM
tictac's Avatar
tictac
Default keyless entry lock beeping twice issue.
I normally use the keyless entry to lock my car when I walk away. However, today for some reason it "beeped" at me. Normally it beeps twice when a door is open or the like. However I have slammed both doors and the trunk. I have also made sure that the lights were all off inside, to include the dome light (that is normally turned on by turning the light switch pass the click) . The only thing I get is the dome light stays on and the keyless entry beeps twice. I couldnt figure what the issue was, so I pulled out the dome light as not to drain the battery and came and consulted you guys.
hopefully someone can help me. [&:] thanks in advance.
Old Mar 1, 2006 | 11:27 PM
gt96stang's Avatar
gt96stang
Default RE: keyless entry lock beeping twice issue.
I know on my 96 when I hit the button twice it makes the horn beep. Maybe you should try that.. Because if I just hit it once, it turns off the dome light and locks the doors.
Old Mar 2, 2006 | 12:10 AM
tictac's Avatar
tictac
yes, i know that. i normally hit it twice to get it to beep. however now when i hit it once it beeps twice like a door is open or something, but there isnt.
Old Mar 2, 2006 | 01:22 AM
Blue99's Avatar
Blue99
My '99 Mustang does this periodically. Don't know why. Although I suspect a loose connection in one of the door switches. If someone could help me remove these, I might be able to fix it. However, you shouldn't have to pull the bulb. The computer should shut them off within 30 minutes.[&:]Blue99RT
Old Mar 2, 2006 | 03:14 AM
gt96stang's Avatar
gt96stang
In my old 97 taurus sho, it did that one time..it kept thinking that a door was still open and it would beep twice to let me know.. I sprayed down the latches with some wd-40 and it quit.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:58 PM
