running strait pipes
Old Mar 4, 2006 | 01:57 PM
Twister's Avatar
Twister
Default RE: running strait pipes
ORIGINAL: JD1969
ORIGINAL: mustangman02232
ORIGINAL: Twister
true straight pipes will produce LESS power than a H or X pipe.
less torque, cause there is less back preasure.
It will move the torque and HP peak higher in the rpm, in most cases.
not always, the cross-over equalizes the air flow and helps move the air out quicker, if a pair of straight pipes produced more HP at 7500-9000 RPM, then why does NASCAR run X pipes?
Old Mar 4, 2006 | 04:38 PM
razarr69's Avatar
razarr69
aren't you just talking about removing the mufflers and leaving the midpipe? it'll be loud, not necessarily good sounding but like said it'll move your power and torque curve up.
Old Mar 4, 2006 | 04:57 PM
fastmofo's Avatar
fastmofo
i think ill take the hit and just go with a magna flow or borla H-pipe.3"would prolly do the trick
Old Mar 4, 2006 | 06:43 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Twister
ORIGINAL: JD1969
ORIGINAL: Twister
I meant that it shifts the torque/power curve upwards, I was commenting on the misconceprion that a loss of backpressure making it lose torque. I did not mean to imply anything about an X pipe.
2007CalSpec
Dec 13, 2020 11:42 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Webster454
Sep 7, 2015 04:59 AM
Emblazoned
Sep 3, 2015 10:45 PM
