Tire Pressure
Old Mar 5, 2006 | 06:22 PM
MustangChris04's Avatar
MustangChris04
Default Tire Pressure
I have Nitto 555r's and 555's . It says Max tire pressure is 44 psi.
What would be an ideal tire pressure for these tires so that they will last the longest??
Thanks.
Old Mar 5, 2006 | 06:40 PM
mustangman02232's Avatar
mustangman02232
Default RE: Tire Pressure
look at what it says on the door of the car, however, it is better to be a few pounds over then a few pounds under.
Old Mar 5, 2006 | 06:46 PM
Djs94stang's Avatar
Djs94stang
The pressure recommended by the manufacturer is to help maintain the contact patch of the tire on the ground. I use 33-34 front and 29-30 rear. I find these pressures help to reduce understeer a bit.
Old Mar 5, 2006 | 06:53 PM
MustangChris04
thanks for the replies. I cant use the tire pressure that is says on the door, They are totally different tires. Does anybody have these tires and know whats best?
Old Mar 5, 2006 | 07:17 PM
hurleymasta's Avatar
hurleymasta
id go with the tire pressure that it says on the tires...that is how you get the best mileage out of the tire at least, if you want more grip, go with less pressure, i would NOT go over the MAX pressure.....that isnt a good idea AT ALL
Old Mar 5, 2006 | 09:41 PM
StickShifty's Avatar
StickShifty
i forget what the door jam says, but i try to run 30psi at all four corners even tho my left rear is leaking alot on my winter tires.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
