Anyone run the trick flow track heat heads,upper and lower intake set up???
Im just starting to build my 1990 Gt motor and was thinking of a 306 block with trick flow track heat heads and upper&lower track heat intake setup. I was wondering if anyone has run this and what cam, t-body, maf..... would be the best set up for the street. Any info would be great THX
RE: Anyone run the trick flow track heat heads,upper and lower intake set up???
i have the tfs tw kit on one of my mustangs ,& i really like it . i also have what ikey ^ said. i think you will be pleased. you are talking about the tfs kit for about $2100 correct?
I didnt buy the kit because the kit comes with the twisted wedge head and i wanted a little more beefy head so i got the track heat heads and track heat intake setup. Know i know that trick flow says that these heads are not 50 state emission legal and the intake is not designed for an egr. the track heat intake has a 12" runner and the tw heads have a 15" runners. shorter the runner more top end u can produce. I think im going to use a 1" spacer and run the egr spacer????? any body done this
inyadreems
08-21-2015 09:10 AM
