347 stroker 150 N2o shot????
Old Feb 17, 2004 | 10:21 PM
Macbeth's Avatar
Macbeth
Default 347 stroker 150 N2o shot????
currently my mustang is running with a 150 n2o system, 355 gears, 3500 stall, b&m shift kit, but i am having a shop build me a 475/347, i got all the motor specs from an issue of "Muscel Mustangs and Fast Fords" and im moving to 411 gears and drag raiduls, 1-3/4 hooker super comps. and 3' exhaust and im also keeping my n2o system
what kind of times can i expect to run though the 1/4
Old Feb 19, 2004 | 04:39 PM
red347's Avatar
red347
Default RE: 347 stroker 150 N2o shot????
Can't really make a prediction without knowing what the car weighs (with driver). Tire size, suspension setup, is the 3500 stall the right stall? etc.
I run a 347 CI, C4, 4.56 gears. Weight with driver is 3020. N/A the 347 went 10.68. With a 150 shot..see below.
Old Feb 20, 2004 | 01:38 AM
Macbeth's Avatar
Macbeth
car weighs about 3500 lbs and im running stock suspension, with subfram connectors. tires are 275/60/15's, comp solid roller cam 0.621 lift . 185cc AFR heads, ported an polished, holly system max ll upper and lower intake, 7 quart mororso oil pan,
Old Feb 20, 2004 | 02:20 AM
red347's Avatar
red347
11.00-11.30 at 120-124 MPH. Roll cage in already?
Ron
Old Feb 20, 2004 | 03:36 AM
Macbeth's Avatar
Macbeth
no, no roll cage yet
Old Feb 21, 2004 | 04:04 AM
Macbeth's Avatar
Macbeth
what kind of roll cage do i need to be NHRA certified to run in the 10's with a convertable???
where would i find such a roll cage????
Old Feb 21, 2004 | 01:09 PM
Quik's Avatar
Quik
with a covert. you need a cage soon then a hardtop. mid 12s for a convet. and 11.99 for a hardtop. 8point is needed.
Old Feb 27, 2004 | 10:19 PM
Sidewayz6.0's Avatar
Sidewayz6.0
13.99 and faster you need a cage, (or at least a roll bar) with a convertible. I've been thrown out of RT66 many times. Just find an outlaw track like US41 in Indiana.
They don't care if you run 9's on a big wheel with no helmet in your underwear.
Old Feb 28, 2004 | 04:56 AM
red347's Avatar
red347
You might try http://www.wildridesracecars.com/cages2.html
Ron
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
aleit2013
Sep 4, 2015 11:58 AM
