Auto's better right?
Old Mar 9, 2006 | 04:51 PM
Dan9687's Avatar
Dan9687
Default Auto's better right?
Correct me if Im wrong but for str8 away racing(no turns etc.) isnt a Automatic with flash tuner better than a manual?
For example same exact car..lets say stock 2000 GT stang but one was manual and the other Auto but with flash tuner. Who would win?
Old Mar 9, 2006 | 05:12 PM
turbostang21's Avatar
turbostang21
Default RE: Auto's better right?
manual will win..mustang auto's lose alot of power though
manaul ls1 vs auto ls1 is about even, but i'd still take manual any day of the week and twice on sunday
Old Mar 9, 2006 | 05:47 PM
ShadowDrake's Avatar
ShadowDrake
You lose more power through the Automatic transmission, than you do with a manual... but the Auto never misses a shift and shifts consistantly every time. At closer to factory power, the manual will be better... At higher power (500+) the auto will do better more often than not because of its consistancy.
Edit: And the manual is just more fun. I wouldn't have an auto stang... ever.
Old Mar 9, 2006 | 08:38 PM
Dan9687's Avatar
Dan9687
How can a Manual be more powerful than an auto when the auto would have a flash tuner like I previously stated? I say this becaus the tuner can allow you to adjust the auto's shift points therefor making it shift at high RPM's just like the manual. Please explain.
Well I ask because somone once told me and I agree, that the auto would be faster because no human can shift as fast as a auto transmission.
Old Mar 9, 2006 | 08:49 PM
GreyStang's Avatar
GreyStang
ORIGINAL: Dan9687
The engine itself has the same power output in both cars. But an auto trans robs more power in it's operation than does the manual trans
Old Mar 9, 2006 | 09:01 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: Dan9687
An auto has a torque converter, which is a fluid coupler, it causes more power to be lost as it is not as efficant as a clutch. Plus the gear ratios are different in the stick, generally they are a little steeper because there are more gears. I highlighted the part that is very untrue, you probably have never seen a good manual driver (and I mean really good, not just a kid who thinks they are good. In higher HP cars the auto is generally faster because the car will 60 foot better due to the converter making the car easier to hook up.
*EDIT* flash tuners do not do crap for an auto, they firm up shifts a bit and can move the shift points but thats it. The real performance comes whne you do a converter swap.
Old Mar 9, 2006 | 09:10 PM
DarkShadowGT03's Avatar
DarkShadowGT03
Manuals are quicker, but you can't mess up on autos. Let go of brake, push gas until you reach finish line.
Old Mar 9, 2006 | 11:18 PM
gt96stang's Avatar
gt96stang
ORIGINAL: JD1969
ORIGINAL: Dan9687
Finally someone that knows what they are talking about... All these people believe into the internet hype...
Old Mar 10, 2006 | 12:24 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: JD1969
ORIGINAL: Dan9687
Not entirely true. With the tuner, you can also adjust the shift pressure. In effect, you get a shift kit without the mess. I have mine set at 80PSI, but can go as high as 120PSI.
Old Mar 10, 2006 | 05:44 AM
sandcracker21's Avatar
sandcracker21
i love my tuner, it definatly kicked my car in the *** and told it to get goin
