T-5 Help, leaking around the driveshaft
Hey, I have a '67 coupe that I'm doing a T-5 swap into. I got a rebuilt T-5, and I'm almost finished with the swap. I was squirting the tranny fluid in tonight when I noticed that it was dripping from around the driveshaft. Anybody know whats going on with this? I need help as quick as possible.
RE: T-5 Help, leaking around the driveshaft
Couple things might be wrong. First look at the Yoke that goes into tail input of the transmission. Does it look like it is gouged, pitted, worn or damaged? If not, it just might be the seal that goes around the yoke. Easy to change, but you must drain the transmission.
Kev
Kev
bradleyb
11-27-2015 07:50 PM
Matt's 95 Stang
10-05-2015 07:16 AM
