Headlight Switch Removal
Old Mar 14, 2006 | 07:54 PM
citydude's Avatar
citydude
Default Headlight Switch Removal
Can anyone tell me how to remove the headlight switch stem so I can remove the dash cluster?
Old Mar 14, 2006 | 08:04 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Headlight Switch Removal
Type of car?
Old Mar 14, 2006 | 09:02 PM
citydude's Avatar
citydude
2002 Mustang
Old Mar 14, 2006 | 10:51 PM
ShadowDrake's Avatar
ShadowDrake
Pull it out so your lights are on. Take a small screwdriver, and pry up from the back (it's tough to get a good angle) on a little metal clip that is inside in a slot on it. You don't have to pry hard, it only has to come up a little. It will then slide right off, while you are holding that little metal piece up. Get a look at it before you pry on it.
Old Mar 15, 2006 | 12:14 AM
Tac2cul's Avatar
Tac2cul
ORIGINAL: ShadowDrake
+1
but when i did mine the **** came off the metal clip and the clip stayed on the stem and i still cant get it off till this day and i have removed the cluster a couple times. As long as it works
Old Mar 15, 2006 | 01:51 PM
citydude's Avatar
citydude
Thanks for the help in the getting the headlight switch off!
Help Again Please!
I am changing speedometer cluster in my 02 Mustang V-6.
I have replacement out of 02 V-6. But the car will not start and (THEFT) light stays on very
bright.
Is the speedometer not compatable? or is there a reset procedure with the new installation?
thanks for your help with this.
Old Mar 15, 2006 | 04:06 PM
ShadowDrake
You need to put your old cluster back in, and drive it over to the Ford dealership. Go inside and describe the problem, tell them you can swap both clusters, and that all they need to do is fix the problem with PATS. Once they agree, take out your old cluster (while you're parked at the dealership), put the new one in, and let them know you're ready. They'll bring out a portable PC-type of thing, hook it up to the OBD-II port and fix the problem for you. You will need both keys there, and both keyless entries. They may charge you for an hour's labor, or if they're nice, do it for free because it only took them about 5 minutes worth of time.
They can NOT adjust the mileage on your new cluster, so they will have to record your old mileage before you remove the old cluster. Write it down when you get there and save them the trouble... it will be good for your records too, in case you decide to sell the car. You will need to report accurate mileage.
Edit: I know because I had to deal with the same problem. After screwing up my instrument cluster trying to install white face gauges (I accidentally bent a pin the needles go on), I bought a cluster from an 01 Cobra on eBay (dirt cheap ) that only had 0.5 miles on it, swapped it and had to put my old cluster back in and go to Ford to have them fix this for me. The codes for the keys, AND the odometer is stored in the instrument cluster, NOT the ECU. Don't let anyone tell you any differently.
Old Mar 15, 2006 | 07:55 PM
citydude's Avatar
citydude
Thanks for your Help. Your information has been very helpful. I will give this a try. I sure appreciate the
help.
StalkerGT
Nov 28, 2015 03:09 PM
jhawkr
Oct 30, 2015 01:55 PM
Colin Ringle
Sep 15, 2015 09:27 PM
wawagner82
Sep 13, 2015 09:02 AM
vintageaion
Sep 8, 2015 10:45 AM
