headlights
Old Mar 19, 2006 | 03:06 PM
Red FIVE O's Avatar
Red FIVE O
Default headlights
ok so i wired up a relay to take care of the headlights...because the stock setup kept melting th MF switch. i put in a 10 amp fuse in the relay circut like the fuse panel said it should need but the fuse is going out. does anyone have a suggestion of what should i do????
thank you in advance.
Old Mar 19, 2006 | 05:08 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: headlights
You need to find the source of the problem. Some thing in the circuit is either shorted to ground or has a bad connection causing resistance in it causing the fuse to blow.
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
