IS A 68 BLOCK OK?
Old Feb 26, 2004 | 03:53 PM
jdmustang302's Avatar
jdmustang302
Default IS A 68 BLOCK OK?
I HAVE A 1968 MERCURY MONTEGO WITH A 302 2 BARREL CARB, I HOPE TO INSTALL IT STOCK IN TO A 1983 MERCURY CAPRI. I WAS CURRIOS AS TO IF THE BLOCK ECT. IS SUTTIABLE TO BE REBUILT INTO A 300+ HP MOTOR DOWN THE ROAD OR SHOULD I LOOK FOR A DIFFERENT YEAR. ALSO ANY OTHER CAHEP TRICKS ANYONE KNOWS WOULD BE GREATLY APPRECIATED. LIKE WILL 69-71 351W HEADS GET ME MORE POWER OR CLEVLAND HEADS? tHANX FOR ANY INFORMATION.
Old Feb 26, 2004 | 07:20 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
Default RE: IS A 68 BLOCK OK?
older blocks are better ..stronger ..thicker cyl, walls,,,i would get some perf, alum heads ,,by the time you spend on them ,,with hardened seats on all the works ,,2/300 for bucks more could get you a good set of heads ,,,
Old Feb 26, 2004 | 07:23 PM
vfast's Avatar
vfast
I ♥ Acer
good seasoned block put some .30 over slugs flat tops a nice cam and some alum heads with a single plan intake and a 750 vac sec. carb
Old Feb 26, 2004 | 07:54 PM
jeep45238's Avatar
jeep45238
I ♥ Acer
As long as a block is taken care of and maintained, I'd rather work on one of those out of a civilian vehicle.
Heaty cycling......that's the oooooonly reason why I won't buy an ex-cop car or fire fighter vehicle.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
