Electric choke
Old Mar 4, 2004 | 12:49 PM
wadeb3's Avatar
wadeb3
Default Electric choke
Quick question: Is there anyway to adjust the electric choke on my carburetor? The sensor is attached to the intake and it seems to take forever to warm up. Just curious. Thanks!
Old Mar 4, 2004 | 01:29 PM
WNDSOR's Avatar
WNDSOR
Default RE: Electric choke
might need a new choke stat, will open up quicker, .02 worth
Old Mar 4, 2004 | 05:20 PM
VertStangGT86's Avatar
VertStangGT86
Junk that and go with a manual choke kit. My dad used to have trouble with his on his when he had an 85 GT. He finally got sick of it and went with the manual and it worked a lot better.
Old Mar 4, 2004 | 07:29 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Ive got a 1406 edelbrock and it starts right up and cold idles at 650rpm and at warm it idles at 550rpm with no stumble or stalling.
I suggest you look on the side of the choke housing theres either two or 3 depending on the carb screws holding it on loosen these up and you can then rotate the choke housing and adjust your check.There should be markins on it indication rich or lean. after you get it set tighten them screws up and youre set to go.
It may take a few mornings of you adjusting it to get it just right but its worth the 2-3 minutes it takes to do this.My carb is so perfectly tuned i can go out with it beingcolder than a witches tit and fire it up and it runs and idles as smooth as efi.
Old Mar 8, 2004 | 11:31 AM
wadeb3's Avatar
wadeb3
Thanks, GMKiller. You were dead on.
Old Mar 12, 2004 | 06:49 AM
e40water's Avatar
e40water
thats the dif with cab vs EFI, carbs will let you know when they are going to die, EFI just goes dead,
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
