What would you Pick?
Old Mar 30, 2006 | 02:36 PM
burnrubber_69's Avatar
burnrubber_69
Default What would you Pick?
What would you pick?
A.> Bosch platinum 2's
or
B.> Autolite iridium
Old Mar 30, 2006 | 05:20 PM
2VNA's Avatar
2VNA
Default RE: What would you Pick?
autolite or NGK
Modular Spark plug list!
This list was originally started by ALLMTR2V on the corral and alot of people helped to get it right. I thought it would be a good addition to the MD!
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - copper plug
AWSF-22C / 1 Heat range colder - copper plug
AWSFA-12C / 2 Hea range cooler - copper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
BP7EFS (PN - 3526) BR7EF (PN - 3346) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
Old Mar 30, 2006 | 11:02 PM
waxyourboard's Avatar
waxyourboard
I'd go for whichever one is cheaper. You can go on www.wikipedia.com and look up the differences between platinum and iridium.
PS. What's your setup? If it's anywhere near stock, special plugs won't really do anything. I switched to Bosch Platinum 4+ and didn't notice a thing.
Old Mar 31, 2006 | 12:28 AM
COMPMACH's Avatar
COMPMACH
Whats it help by running a cooler range spark plug?
Old Mar 31, 2006 | 01:51 AM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
Colder plugs help prevent detonation in boosted, nitrous or high compression motors. Basically stock or hotter plugs hold more heat and therefore can cause detonation in certain instances.
jwog666
Dec 27, 2021 08:09 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
KingRando
Oct 2, 2015 08:06 AM
mdg
Oct 1, 2015 07:04 AM
