good idea or bad
Old Mar 31, 2006 | 01:13 PM
2VNA's Avatar
2VNA
Default good idea or bad
I just got a new intake and the adapter that go's on the MAP to connect the air filter I had to seal. I put a bead of black Silicone on the inside between the plate and the MAP. The reason I am asking is I was wondering if it would dry out and fall off?
http://i83.photobucket.com/albums/j3...A/IMG_0182.jpg
Thanks for all the help
Old Mar 31, 2006 | 01:34 PM
MustangChris04's Avatar
MustangChris04
Default RE: good idea or bad
that is something I wouldnt want to do if I were you.
Old Mar 31, 2006 | 01:44 PM
motormike's Avatar
motormike
whats the set up look like?
im not sure if that will hold together
Old Mar 31, 2006 | 01:46 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That silicone better be sensor safe first off. Secondly, take a razor or exacto knife and get rid of that bead that is in the air pathway. You're actually negating any positive effects by distorting the incoming air.
Old Mar 31, 2006 | 01:50 PM
2VNA's Avatar
2VNA
Here is the pick if my engen bay, you can see the MAP there and the adapter between that and the filter, I have sealed it on the outside and the inside there is about a 1/8" lip on the inside because the adapter is a little large than the MAP.
http://i83.photobucket.com/albums/j3...A/IMG_0170.jpg
djbigskrilla
Sep 20, 2022 01:04 AM
Urambo Tauro
Oil and Oil Related Topics
Dec 11, 2017 07:16 AM
Faolan65
Aug 27, 2015 06:40 AM
kdryan
Aug 21, 2015 04:01 PM
makatak123
Aug 17, 2015 03:06 AM
