Need Help!! 86 SVO Probs
Old Apr 1, 2006 | 06:55 PM
86_SVO_Tim's Avatar
86_SVO_Tim
Default Need Help!! 86 SVO Probs
I have an 86 SVO Mustang(2.3ltr. Turbo) It's idling at nearly 2500rpm's but will idle normal when i take the rear breather out of the valve cover.....there is a massive amount of vacuum in the valve cover(it will suck your finger right down into the breather hole) Any clue what in the hell is causing this? I have went through all of my vacuum lines and everything is good. Take note, when i parked it for the winter season i did not have this problem but now that nice weather is here i got it back out and it is doing this. I am totally confused with it! Any help would be greatly appreciated!
Old Apr 1, 2006 | 07:15 PM
alexr's Avatar
alexr
Default RE: Need Help!! 86 SVO Probs
try posting this in the v6 & 2.3, turbo section
also post some pics
Old Apr 1, 2006 | 07:43 PM
Tim37's Avatar
Tim37
is the vacume form the valve cover or the hoes going to the valve cover?
btw that should be your pcv valve.
Old Apr 2, 2006 | 12:51 PM
TBird232ci's Avatar
TBird232ci
Use a Motorcraft PCV valve, that should fix your problem
jwog666
Dec 27, 2021 08:09 PM
1996cobraconvertible
Sep 25, 2015 03:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
DaveAllred
SVO Forum
35
Jan 30, 2008 07:37 PM
DaveAllred
Feb 29, 2004 01:22 AM
