Sponsored by:
Sponsored by: DashLynx
Dueling Mechanics- who is right?
Old 04-03-2006, 08:19 PM
Lord Ashram
Lord Ashram's Avatar
Default Dueling Mechanics- who is right?
Lord I hope someone here can help...
I have a 2000 GT with a rebuilt 4.6 with a vortech blower.
A new mechanic was just looking at it and was upset by my sparkplugs. Said I had .020 gap copper plugs, and that I should have .056 gap platinums. I called Vortech and they said .035 copper. Anyone have ANY idea which is the right one?
This is killing me
Thanks!
Lord Ashram is offline
Old 04-03-2006, 08:45 PM
Machwon
Machwon's Avatar
Default RE: Dueling Mechanics- who is right?
for a power adder application- s/c and especially nitrous you want to avoid detonation at all costs- one great way to do this is by using a colder (heat range) plug. Platinum is a bad idea IMO- I would use NGK TR6s. They work great and are 1.99 a piece. Also set gap between .030 and .035. Hope that helps!
Machwon is offline
Old 04-03-2006, 08:49 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Mechanic is looking at factory spec, not the modded spec.
Frequent thing that mechanics overlook is a Modified car. I.E. factory spec on the car tires is 32PSi, however that is on a tire that is rated at 35PSI max or stock. I have low profile BFG KDW tires that are rated at 44PSI Max so I run them between 35-38 PSI. Tech tried to tell me I should run at 32PSI as stated in the owners manual. I told him that's great for a STOCK tire and asked if he would replace a $155 if it blew on account of his error. That ended the convo.
Derf00 is offline
Old 04-03-2006, 09:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Machwon
Agree^^^ Although I use autolites in mine. .030 gap, 2 heat ranges colder.
PRO50SC is offline
Old 04-04-2006, 02:28 PM
dsum14
dsum14's Avatar
Yep. .030 colder plug. I would trust Vortech over the mechanic anyway. They designed the system and know the best combo for it to work properly.
dsum14 is offline
Old 04-04-2006, 04:33 PM
turbostang21
turbostang21's Avatar
it really depends on how much boost and power you're making... this should be a sticky and the info was borrowed
Spark Plug FAQ
Stock Heads also (Dart Windsor Jr & Sr)
Naturally Aspirated (non-projected tip)
NGK
Specifications:
Thread Size= 14mm
Hex Size= .625
Reach= .46
Seat Type= Tapered
Electrode= V-Power
NGK R5673-6 Stock Number 2405 (1 heat range hotter)
NGK R5673-7 Stock Number 2817 (Factory heat range)
Specifications:
Thread Size= 14mm
Hex Size= .625
Reach= .46
Seat Type= Tapered
Electrode= V-Power
Autolite Stock Heads
Autolite 25 Naturally Aspirated
Autolite 24 1 Heat Range Colder
Autolite 23 2 Heat Ranges Colder
Autolite Race Series for Stock Heads
Autolite AR135 Naturally Aspirated Only
Autolite AR134 1 Heat Range Colder
Autolite AR133 2 Heat Ranges Colder
NGK Forced Induction
NGK-Non Projected Electrode
Specifications:
Thread Size= 14mm
Hex Size= .625
Reach= .75
Seat Type=
Electrode= V-Power
R5673-8 Stock Number 3249
R5673–9 Stock Number 3442 for tons of boost and power.
Aftermarket aluminum heads (TFS, Edelbrock, AFR, Canfield, Brodix)
R5671-A8 Stock Number 4554, 1 heat range Colder (up to about 600rwhp)
R5671–A9 Stock Number 5238, for 18+psi, 2 heat ranges colder 650+ rwhp
R5671–A10 Stock Number 5820, for race cars.
Autolite Forced Induction and N/A
Autolite 3924's Naturally Aspirated Only
Autolite 3923’s 1 Heat Range Colder, good for approx 550rwhp
Autolite 3922’s 2 Heat Ranges Colder, good for approx 650rwhp
Autolie Race Series for aftermarket heads
Autolite AR3935 Naturally Aspirated Only
Autolite AR3934 1 Heat Range Colder
Autolite AR3933 2 Heat Ranges Colder
Plug Specs for GT-40 Iron, GT-40 Aluminum, GT-40X, & GT-40P Heads
Thread Size- 14mm
Hex Size- .625
Reach- .708
Seat type- Tapered
Electrode- Standard Nickel
Projected Tip
The stock equivalent replacement part numbers according to the Motorsport Catalog are:
Ford MotorSport Part Number AGSF-32C for the GT-40 Aluminum, and GT-40X
Ford MotorSport Part Number AWSF-32C for the GT-40P, and GT-40 Iron
These plugs cross to:
NGK - BPR6EFS Stock Number- 3623 (Stock Heat Range)
Autolite- 104
These are the NGK Race Series Part numbers and specs:
Thread Size- 14mm
Hex Size- .625
Reach- .708
Seat type- Tapered
Electrode- V-Power
Non-Projected Tip
NGK- R5724-8 Stock Number- 7317 (1 Heat Range Colder)
NGK- R5724-9 Stock Number- 7891 (2 Heat Ranges Colder)
NGK- R5724-10 Stock Number- 7993 (3 Heat Ranges Colder)
turbostang21 is offline
Old 04-04-2006, 04:34 PM
turbostang21
and you gap should be around .030
Old 04-04-2006, 07:16 PM
wildcobrar
wildcobrar's Avatar
Yes I agree, a couple steps colder on the heat range plus a copper style plug and a .030 gap. Moat platinum plugs have a fine or small tang on the electrode. In a power adder car, these can run hot and create preignition and cause engine damage. You also tighten the gap up to help prevent the boost from nullifying the spark which happens on a wider gap.
wildcobrar is offline
Old 04-04-2006, 08:16 PM
Lord Ashram
Wooo that post was a mouthfull; I have to admit, I didnt quite get it!
Is there an exact sparkplug I should be looking at? Its a 4.6 with vortech s trim, making like 11 or so psi, aftermarket heads... well heck, the info is in my signature I guess Any ideas?
Thanks!
Old 04-05-2006, 12:03 AM
waxyourboard
waxyourboard's Avatar
ORIGINAL: wildcobrar
The development of precious metal high temperature electrodes (using metals such as yttrium, iridium, platinum, tungsten, or palladium, as well as the relatively prosaic silver or gold) allows the use of a smaller center wire, which has sharper edges but will not melt or corrode away. The smaller electrode also absorbs less heat from the spark and initial flame energy
waxyourboard is offline
noir
01-17-2006 12:12 AM
mustangjenni
08-29-2005 10:22 PM
Badash
06-10-2005 09:06 PM
Ge0FfSt@nG69
07-07-2004 05:18 PM
Fourtwozero
01-07-2004 05:29 PM
Quick Reply: Dueling Mechanics- who is right?
