swapping to 460 bnig block, t5 question
Old Apr 4, 2006 | 09:58 AM
ncksnapper's Avatar
ncksnapper
Default swapping to 460 bnig block, t5 question
anyone know if the bellhousing on a 302 ho will bolt to a ford big block? im gettin a 460 for cheap if it will work without major modification thanks for the help guys
Old Apr 4, 2006 | 02:22 PM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
Default RE: swapping to 460 bnig block, t5 question
No, a small block bellhousing will not bolt to a bigblock. I wouldn't use a T-5 behind a 460 anyways, it will be trashed in short order. You will need a new oil pan, headers and motor mounts to put the 460 in your car that is an easy $1000 if you find good deals and you haven't begun to address the cooling, fuel and suspension. There is nothing cheap about a big block swap for a late model Mustang. I have done it, there is a good bit of work involved and lots of things that will nickel and dime you.
Old Apr 4, 2006 | 02:57 PM
ncksnapper's Avatar
ncksnapper
the only reason i was gonna do it cause i can get the motor, but what about a 351 windsor, does my tranny bolt to that? and what bout my motor mounts? the guy that has the 460 has a 351 w
Old Apr 4, 2006 | 03:52 PM
QuickShortBus
I ♥ Acer
Yes a 351W will bolt to your T-5 bellhousing. But, I wouldn't expect the trans to last long. A basically stock 302 with a few bolt-ons can break a T-5 the extra torque from a 351 will make it that much easier.
You will still need new headers and a 351W oil pan for a fox chassis, you are looking at $400 for those items if you buy a stock type pan and shorty headers. You might be able to get away with your stock mounts, but you could run into clearance issues with the intake and hood. Also, remember your current intake won't fit a 351, so you will need a new intake, unless the motor comes with one that will work for you (which is doubtful). With any motor swap little things are going to nickle and dime you. There is no such thing as a cheap motor swap (unless you can fabricate everything that's needed).
Edit: You will need a new distributor also.
Old Apr 4, 2006 | 04:50 PM
ncksnapper's Avatar
ncksnapper
im converting to carb, and i have brand new solid motormounts and i just picked up a 4 inch cowl hood from the same guy with the engine, where do i get the oil pan? and the headers, i should be fine with the t5 for now if i dont beat on it to bad right?
it has a distriutor, its out of a 65 ford truck that distributor wont work?
Old Apr 4, 2006 | 05:26 PM
QuickShortBus
I ♥ Acer
Mac makes a reasonably priced shorty header, Ford sells a swap pan for a reasonable price or I actually have a Moroso 7qt pan I need to sell. That distributor should work as long as you don't put a Victor Jr or Victor intake on it, they require an MSD distributor.
The T5 will work just don't beat on it, I would go ahead and sell it while it still works and put the money towards a TKO 600.
Old Apr 4, 2006 | 05:38 PM
ncksnapper's Avatar
ncksnapper
ok good, thanks for your help , how much do u want for the oil pan, and what intake do u recomend im puttin a cam in it to
Old Apr 4, 2006 | 09:34 PM
QuickShortBus
I ♥ Acer
The cam and intake are going to depend on your intended use and what you are using for heads.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
