dyno tune
Old Apr 9, 2006 | 03:24 AM
likenew94stang's Avatar
likenew94stang
Default dyno tune
Im about to install the COMPLETE Trick Flow Top End kit (TW heads, Cam, timing set, Track Heat Intake), #24 Ford Racing Injectors w/ matching 70mm BBK TB, 190lph fuel pump, Aeromotive ADJ. FPR, new alternator, power steering pump, tensioner assembly, oil pump, waterpump, King Cobra Clutch, Ford Racing adjustable clutch cable...
I know the sn95 computers are moody w/ mods, but will a good dyno tune make everything work flawlessly? Anything I should make sure to ask for?
Old Apr 9, 2006 | 03:49 PM
w8less's Avatar
w8less
Default RE: dyno tune
yes a good dyno tune with a good custom chip burned for it will cure the surging issue u will have when u change the cam out
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixx
Oct 5, 2015 07:36 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
