Ford Variable Timing
Old Apr 9, 2006 | 10:58 PM
Tik_Tok's Avatar
Tik_Tok
Default Ford Variable Timing
Anyone know (or have a link to a site) about Ford's variable timing, and how it work? I'm rather curious.
Old Apr 10, 2006 | 12:43 AM
kartracer55's Avatar
kartracer55
Default RE: Ford Variable Timing
OK.... well im guessing you know the basics... Basically fords variable CAM timing is a form of Variable valve timing. Its accomplished by rotating the whole camshaft (advancing/retarding in relation to the cranks rotation) using an oil pressure controlled solenoid on the cam driver... simple right VTEC's use 2 lobes and a follower on the larger one. When the engine reaches the Set rpms a solenoid kicks open using oil pressure to move a pin that locks the rocker arm to the follower on the larger lobe, so the valve follows the larger profile. These are the two basic methods for variable valve timing in most engines
That what you were lookin for?
Jim
jpplaw
Mar 19, 2025 08:53 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
algregory
Sep 6, 2015 05:52 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
UINZWAY
S197 Shelby Section
Aug 5, 2015 10:34 PM
