Cam sensor
Old Apr 24, 2006 | 07:39 PM
Hammy's Avatar
Hammy
Default Cam sensor
I have my 1998 Mustang (V6) in for repairs. The initial concern was that a belt or pulley in the fan belt area was bad because the car makes a "chirping" sound (like I got a bunch of caged tweetie birds in the engine) when I start her up; ocassionally the sound continues though the car is warmed up and on the road. The mechanic called back and said he believes it is a cam sensor. What the heck is a cam sensor and how does that make a chirping sound?
Old Apr 24, 2006 | 07:45 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Cam sensor
is he looking at the right diagnostic sheet? Cam sensor doesn't even move, heck it doesn't even touch the cam (it uses mangetic induction to work).... I think you need a second opinion.
Old Apr 25, 2006 | 10:43 AM
Chopper's Avatar
Chopper
You are about to get screwed.This sounds like the classic belt tensioner chirp.The bearings dry out and fail in the idler pulley and make the sound you describe.Take the car somewhere else or better still,fix it yourself.I would think you could get the part from an auto parts store for less than $50.
Old Apr 25, 2006 | 10:51 AM
BraMas's Avatar
BraMas
Get your car away from that shop now! Your car will not run if the cam sensor is bad. All it does is tell the computer the position of the cam. If the computer does not know where the cam is it won't start. Like chopper said it is just your belt tensioner.
Old Apr 25, 2006 | 01:44 PM
Tac2cul's Avatar
Tac2cul
ORIGINAL: Chopper
+1
Old Apr 27, 2006 | 04:33 PM
I_AV8_4U's Avatar
I_AV8_4U
Hi Hammy.
I doen't mean to rub against the grain here, but I disagree with everyone so far. I have had this problem before (in a v-6). I lost power, when I accelerated, I would get a funny chirping sound, and it progressively got worse. Hooked up the OBD and it said many things, including: Cam sensor, crank sensor, and Mass Airflow Sensor. Since the cam and crank sensors were only around 15-20 each, I replaced them, cleared the OBD and presto - completely back to normal. It was a quick and cheap repair.
I am told that the sensors can go bad slowly, ie not just quit completely (which was my case). It also affected the input to the Mass Air sensor - but the cam and crank sensors fixed the problem and fed the MAS correct info so now it reads correctly.
Yes, Chopper could be right with the belt tensioner theory. If the car runs fine (good power) but you get the chirp, sounds like the belt! If not, go to Autozone and spend $20 and take 5 mins to change it yourself! Autozone.com will give you a how-to with pics!
Good luck.
Troy
PS. Sorry guys! LOL
Old Apr 27, 2006 | 08:33 PM
Krusher's Avatar
Krusher
if the syncro is slightly bent and is actually contacting the sensor it will make that type of noise... those buggeres ain't cheap either... more than likely you're going to have to replace the syncro and sensor... syncro is around $150 and I don't remember how much the sensor is but it's cheaper than $50 I believe...
Old Apr 28, 2006 | 12:11 AM
BraMas's Avatar
BraMas
That's OK to disagree with us. But your situation is IMO a coincidence. There are NO moving parts in a Cam Sensor therefore it can not make a noise. It is nothing but a magnet that senses a protrusion on the cam. And the crank sensor has a timing gear with little teeth with one missing tooth that is how the ECM knows the position of the crank
Old Apr 28, 2006 | 01:12 AM
I_AV8_4U's Avatar
I_AV8_4U
Now that, BraMas, I do agree with!
There are def no moving parts, but the cam/crank sensor will send the wrong signal to the ECU regarding the cam/crank position - hence the noise. Talk to a FORD mech, and they will actually tell you about this, which is how I actually found it!
Thanks for not bashing too hard gentlepeople!
Troy
Of course this is all bunk if the car operates normally, but just has a squeaky noise!
Old Apr 28, 2006 | 01:39 AM
BraMas's Avatar
BraMas
Ok I will have to give up on this one. I think Krusher is a Ford tech so if he says it can make a noise I will have to give up. Just doesn't make sense to me[sm=headbang.gif]
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
