TORQUE STEER FROM HELL
Old Mar 22, 2004 | 11:47 PM
bczapp's Avatar
bczapp
Default TORQUE STEER FROM HELL
ive got a 98 cobra and when i take off the car wants to go left, and when i let off without upshifting it wants to go right, its been lowered with steeda springs and monroe shocks, and the lower control arms are aftermarket (i forgot who makes them) with neoprene bushings with grease fittings, ive checked everything and all the bolts are tight and no sign of wear. ive only got 50k on it and i dont know what do do, please help!!
Old Mar 23, 2004 | 05:20 AM
n2o44's Avatar
n2o44
Default RE: TORQUE STEER FROM HELL
there has to be a bushing that is shot , sometimes you cant see it unless the arms are disconnected . sounds like the rear is trying to turn right , which makes you car go left . torque boxes are not torn i hope , did you ever have slicks on the car? jack your car up from the rear and use a long prybar to see if there is any excessive movement from anywhere . another thing maybe they used bolts that are a lil bit smaller then the hole in the bushings , causing excessive play ,
CS2007
Jun 25, 2019 09:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
stark777
Sep 21, 2015 12:46 PM
