radar dectors?
Old 04-29-2006, 04:56 PM
hookandpull
hookandpull's Avatar
Default RE: radar dectors?
Rocky mountain radar detectors are also awesome. The owner and designer designed the radar jamming packages for the b-2 stealth bomber adn then took his technology elsewhere when his contract was up.
hookandpull is offline
Old 04-29-2006, 05:55 PM
amrcnidyot
amrcnidyot's Avatar
for those of you that have radar detectors that have cords, i did something today that you might like. i have a 00 and i took off the windshield defroster vent and then i fed a wire from the vent down under the dash on the drivers side. i used that to pull the detectors cord through then i put the small end of the cord through the closest vent hole and hooked it to the radar detector. for the end that plugs into the socket, i ran it kinda behind the stereo then i ran the cord out of the botom trim piece and into the socket. sometime soon im going to get a little plate to cover the socket hole and im gonna move the socket and everything behind the trim.
and cobra radar decectors are really good for the money.
[IMG]local://upfiles/31586/2E767804407B4220BEA2147893433EEB.jpg[/IMG]
[IMG]local://upfiles/31586/0843A6F3F6DC4FC9BBCE989F25657A8C.jpg[/IMG]
[IMG]local://upfiles/31586/33B3B4266D2C4648BB7FC8094382769D.jpg[/IMG]
amrcnidyot is offline
Old 04-29-2006, 06:13 PM
MustangChris04
MustangChris04's Avatar
a better way would to be just to cut the plug for the detector and put it into a fuse in your fuse box... now u have the lighter socket available and you dont see any wires at all.
MustangChris04 is offline
Old 04-29-2006, 06:17 PM
amrcnidyot
amrcnidyot's Avatar
yea i thought about that but i really dont wanna cut that wire. i might do it though.
edit: oh and i still do have the other socket by the center consols compartment thing.
Old 04-29-2006, 07:19 PM
kraz3y
kraz3y's Avatar
hey wats that thingamabob by ur leg attached to the red wire??
kraz3y is offline
Old 04-29-2006, 10:21 PM
mustangman02232
mustangman02232's Avatar
just stick it up by the rear view mirror, which is the best place to have it, and run the wires across the top and down the pilar to the fuse box
mustangman02232 is offline
Old 04-29-2006, 10:24 PM
hookandpull
amen!
Old 04-30-2006, 12:41 AM
M1ke
M1ke's Avatar
actually go to k40.com those own all including the v1, passport, and escort. many magazines and websites have tested their line with amazing results. check out their site. it has all of those articles.
M1ke is offline
Old 04-30-2006, 04:53 AM
Retnavy83
Retnavy83's Avatar
I've had a V1 since early '90's. Just recently sent it back for upgrades. The one and only
time I was pulled over with the V1 was when the officer was sitting on a blind corner with
his instant on system. To late to slow down. Otherwise, the detector has never failed
to find the radar unit. As far as too many false alerts, it's not hard to filter them out with
the least sensitive setting. After you get used to the display, you can tell which are false and
which are not.
On the subject of jamming, it's illegal to jam radar! There are two types of laser jammers on the market.
I can tell you one type works well. It'll give you about 5-10 seconds to slow down before the officer can
read your speed. Saved my butt several times in Ohio and elsewhere. The other is called a Blinder. I
don't have any experience with it though.
I hid the flat line for the V1 under the windshield molding and down the pillar. The only piece of wire hanging
is the final tab that plugs into the V1 next to the rearview mirror. I installed another power point under the
passenger side dash for the V1 power plug. Works fine!
Retnavy83 is offline
Old 04-30-2006, 06:07 PM
Chopper
Chopper's Avatar
ORIGINAL: Retnavy83
which are not.
+1 and the arrows are great for tracking the signal's origin.This is just one way you can tell a false alarm from the real thing.V1 all the way.
Chopper is offline
Quick Reply: radar dectors?
