TIRES RUBBING NEED HELP.......
Old Mar 29, 2004 | 08:32 PM
87 mustang gt's Avatar
87 mustang gt
Default TIRES RUBBING NEED HELP.......
HI I INSTALLED A 2INCH DROP ON MY 87 FORD MUSTANG GT ALL THE WAY AROUND .I ALSO INSTALLED 17 INCH RIMS COBRA R WITH 255/40/17 TIRES. THE PROBLEM I AM HAVING IS THE FRONT TIRES ARE RUBBING ON THE INNER FENDER WELL WHEN I BRAKE OR HIT A POT HOLE. NEED INFO. THANKS
Old Apr 5, 2004 | 04:37 PM
cldnails's Avatar
cldnails
Default RE: TIRES RUBBING NEED HELP.......
There is an easy fix as long as they are not running too bad.
"Wheel Spacers" As long as your wheels aren't tucked this should fix the problem.
Buddy of mine had to use them on his S-10 and it worked like a charm!
Old Apr 5, 2004 | 04:54 PM
Obsol3te's Avatar
Obsol3te
I heard somewhere that anything farther then a 1.5" drop would cause problems...
and those tires are too wide anyways for fronts on a fox
8.5" dont rub i believe
Old Apr 7, 2004 | 09:32 PM
VertStangGT86's Avatar
VertStangGT86
I had 245's at one point on the front and they rubbed. If you're doing a 2" drop you should get adjustable camber/caster plates so you can keep the right dynamics in the suspension. If you're rubbing when you stop hard then you're def too big. If you wanna keep them you might try taking out the inner wheel well, like the plastic liner. Depends on how often you drive it though.
Old Apr 15, 2004 | 07:54 PM
87 mustang gt
THANKS FOR THE INFO. GREATLY APPRECIATE IT
Old Apr 15, 2004 | 07:57 PM
87 mustang gt
THANKS FOR THE HELP. I THINK I AM GOING TO CHANGE THE SPRINGS TO 1/5. I JUST RECIEVED BOUGHT 245/40/17. I WANT CHECK IF THESE TIRES ARE GOING TO RUB. IF THE PROBLEM STILL EXISTS THEN THE SPRING CHANGE NEXT. THANKS
Old Apr 19, 2004 | 09:09 PM
87 mustang gt
I JUST INSTALLED 245/40/17 AND THEY WORK THE CLEAREANCE IS PERFECT NO MORE RUBBING.. JACEK
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
