Ford 9 inch
Old May 11, 2006 | 06:28 PM
SurWicked's Avatar
SurWicked
Default Ford 9 inch
Its about time for me to stop babying the car and put some slicks on it so I can get out on the track. I wanted to upgrade my axels because I have seen the damage they can do when they snap. Rather then upgrading to 31’s and changing the dif, also a gear swap… would it be more worth my while just to jump straight into a 9”. Although I do not have the power for it right now, I am looking forward to about ~500hp with my Windsor project and a little squeeze. also when converting over to a 9 inch, can i use all of the breaking system off my 8.8? or will i need to rig something else up?
Old May 11, 2006 | 06:35 PM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: Ford 9 inch
ORIGINAL: SurWicked
9 inch is really the ultimate way to go, I did this about 10-12 years ago when I switched to big blocks in my mustangs. It is the ultimate rear end but an 8.8 will easily handle the power you are talking about. Ask yourself a serious question, realistically will you ever see 800+hp consistently and have the need for constant gear changes? If this is never gonna be an issue build the 8.8 and have fun. Your gonna have to buy axles for a 9 also, not to mention everything else and quality stuff for the 9 that will handle the power isn't cheap by any means. If I was to add up all the money in my rear ends alsone, I bet its close to 10k in 9 inch parts. And no 8.8 parts wont work.
Old May 11, 2006 | 09:48 PM
superfreak's Avatar
superfreak
+1
Old May 11, 2006 | 10:43 PM
gt96stang's Avatar
gt96stang
You can make that 8.8 handle the power that you want it too.
Old May 12, 2006 | 01:49 AM
OICW's Avatar
OICW
I'd also say stay with the 8.8. With the money you'll be dumping into the 9 you might never get to 500 hp
drfister
May 3, 2018 10:38 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
vincep99
Aug 30, 2015 11:42 AM
my96mustang
Aug 24, 2015 06:12 AM
