Battery Relocation Kit
Old Apr 5, 2004 | 12:19 AM
Obsol3te's Avatar
Obsol3te
Default RE: Battery Relocation Kit
hrmm
damn better order my pump/reg and gauge then...
how wide are the stock fuel lines?
and how many 20' lines do i need?
i really have no idea what width lines to order...
Old Apr 5, 2004 | 12:38 AM
roundman's Avatar
roundman
try the stock lines first as they may well be large enough with the bigger pump. I wouldn't change line sizes unless I couldn't get sufficient fuel pressure at the regulator and you won't know that until you install the pump and regulator along with the new injectors. I don't know if they make bigger hard lines, which means you would have to go to high dollar SS braided hose lines and they cost a lot per foot not counting the fittings and adapter needed to make them fit correctly.
Old Apr 5, 2004 | 01:00 AM
Obsol3te's Avatar
Obsol3te
wouldnt the rubber lines stretch n crap?
Old Apr 5, 2004 | 01:11 AM
roundman's Avatar
roundman
stainless steel braided hoses don't stretch enough to worry about.
Old Apr 5, 2004 | 01:16 AM
VertStangGT86's Avatar
VertStangGT86
you've got a fuel pressure regualtor and return line so you don't have to worry about too much pressure building up in the lines. Rubber ones should be fine.
Old Apr 5, 2004 | 10:54 PM
vfast's Avatar
vfast
I ♥ Acer
don't use rubber line as they become brittle....you can use a copper line or stainless steel the sky is the limit on size..your rails will be the problem before the line will ever be..going to a 95 rail as it's just a lil bit bigger
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
flash_xx
Oct 16, 2015 07:23 AM
