Valve Stems: Pull Through or Bolt On?
Old May 16, 2006 | 08:56 AM
verter2's Avatar
verter2
Default Valve Stems: Pull Through or Bolt On?
Which do you guys think are better, last longer?
Old May 16, 2006 | 10:14 AM
verter2's Avatar
verter2
Default RE: Valve Stems: Pull Through or Bolt On?
Anyone have an opinion?
Old May 16, 2006 | 10:17 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Either work fine
Old May 16, 2006 | 02:11 PM
Chopper's Avatar
Chopper
What do you guys mean "bolt on or pull through" valve stems.All valves are one piece?????
Old May 16, 2006 | 03:11 PM
verter2's Avatar
verter2
Some are made so they bolt flush to the wheel. You then remove a screw cap, insert an adapter and then fill w/ air
Old May 16, 2006 | 06:51 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: Chopper
This should enlighten you! Pull through, they just pull through the wheel to seat...
Bolt on, well a , self explanitory....
Old May 17, 2006 | 11:00 AM
Chopper's Avatar
Chopper
OH HE11!!!The valves inside the engine.[:@]DOH!!!
I thought you had all gone nuts or something,"pull through valve stems".[>:]
foxtrot
Sep 29, 2015 06:32 AM
maestro1024
Sep 21, 2015 02:40 PM
ctgreddy
Sep 20, 2015 08:35 PM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
