C&L install
Old Apr 5, 2004 | 06:08 PM
RollinThunder's Avatar
RollinThunder
Default C&L install
hey I just ordered a C&L 85mm MAF system with the K&N filter...what problems might I come across when I do the install??...thanks
Old Apr 5, 2004 | 06:44 PM
Obsol3te's Avatar
Obsol3te
Default RE: C&L install
my 75mm and air filter was extremely easy to do...
not sure u can have any problems...
Old Apr 5, 2004 | 10:00 PM
MelloYello's Avatar
MelloYello
Yup.... Easy bolt on..... Its pretty self explanatory... the only prob you might have is droppin the flat head
Old Apr 6, 2004 | 02:33 AM
RollinThunder
thanks guys!.....another question, I plan in the next month also gettin the C&L inlet tube and there upper intake and a BBK 75mm tb....again would I come across any problems installin those things as well?
and when is C&L gonna come out with there lower intake cuz I was thinking if I should even get there upper intake until there lower one comes out as well.....cuz after all those C&L mods and tb that I listed above I'm gonna have the stang dyno tuned and burn in all 2 a chip so I get the most out of all the mods and also cuz my car is runnin real lean down low ....
so should I wait until the lower intake comes out b4 I do the tune?....thanks
Old Apr 6, 2004 | 05:09 AM
roundman's Avatar
roundman
tune it now before that lean condition hurts a piston or valve.
Old Apr 7, 2004 | 01:09 AM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
There will be no "lean condition" because the Mass air meter will take care of it. You won't have any problem with the C&L MAF. Get the inlet pipe now to make the best out of the mod.
When you do the T/B and plenum swap, there are step by step instructions on the web and in past issues of MM&FF and Mustang Enthusiast magazines. I would do the swap now. The lower will be done by June hopefully and will probably be a job in itself.
Good luck!
mtgldr
Feb 3, 2024 09:00 PM
Jb145700
Aug 21, 2022 06:37 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
