Fuel Problem??...Please help
Old May 20, 2006 | 07:53 PM
stanger24's Avatar
stanger24
Default Fuel Problem??...Please help
I have a '98 3.8L Mustang. When I start it up and take off, it's fine, but soon after it starts acting up. When I'm driving it won't rev past 3K rpms even if i hold it to the floor, and the farther I drive the more RPMs I lose. Today it got as bad as doin that at 2K rpms. It feels like it would when you hit the governor...it just hesitates and won't accelorate. If I barley get into the throttle it'll accelorate a little, but only if i don't get over 3K RPM or more. The check engine light is also on, and has been for a short while. I think it might be an O2 sensor, but I'm not really sure. Can anyone help me figure this problem out? Thanks.
Old May 20, 2006 | 08:01 PM
corvetteguy's Avatar
corvetteguy
Default RE: Fuel Problem??...Please help
Why not change your gas filter.
Old May 20, 2006 | 08:07 PM
hwest's Avatar
hwest
Absolutely on the gas filter. Also check your plugs and wires. Make sure your plugs are seated properly and the wires are on securely.
Old May 21, 2006 | 05:39 PM
rcobra's Avatar
rcobra
Also check vacuum hoses for cracks or disconnection.
Old May 21, 2006 | 05:42 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
How many miles on the motor? Could def be a clogged filter or a converter for that matter. Have the codes read and start there.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
