2.3 TO 5.0 CONVERSION
Old Jun 14, 2006 | 03:00 PM
mustangfever2006's Avatar
mustangfever2006
Default RE: 2.3 TO 5.0 CONVERSION
how hard is the wiring harness to figure out. i am getting reasy to do the same swap.
thanks
Old Jun 14, 2006 | 06:32 PM
mimsy_5.0's Avatar
mimsy_5.0
ITs a pain if you cut the wires. If you have to cut them just make sure you take the time to label each one so you can connect them easily. You shouldn't have to cut it though, you should be able to just remove it whole and transfer it. If I am wrong someone correct me.
Old Jun 15, 2006 | 01:21 AM
anthonydalrymple's Avatar
anthonydalrymple
ORIGINAL: mimsy_5.0
No, you pretty much nailed it correctly.
Ford made all the connectors unique; you can't plug the wrong connectors together. This makes the job easier if the markings you make happen to fall off or rub off.....
Old Jun 16, 2006 | 12:48 AM
mimsy_5.0's Avatar
mimsy_5.0
Hey anthony maybe you can help me out. I just got a used GT40/explorer intake. I don't konw if you know any thing about them but heres my question anyway. I know you yhave to make a few adjust ments to some of the vacuum lines that arent needed on the underside of the upper manifold but I am not sure which ones. ALso as far as plugging the useless ones, do I just clip off the line to make it shorter than put a rubber plug at the end? Hopefully you can help or maybe know of a website that could. THanks
Old Jun 16, 2006 | 01:52 AM
anthonydalrymple
I've helped a local friend with his & my first Exploder intake coversion. But since the car does not yet run correctly; i really do not want to give specific advise yet until we figure out what went wrong....
This'll get you started though.....
http://www.allfordmustangs.com/Detailed/614.shtml
http://www.geocities.com/blackninetylx/Explorer.html
Old Jun 17, 2006 | 03:03 PM
mustangfever2006
are the plug for the gauges the same between the 87 5.0 and 85 2.3. and all of the acc. plugins
mustang0291
Oct 12, 2015 07:55 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
