carburator rebuild?
Old May 25, 2006 | 09:27 AM
dennisshoe's Avatar
dennisshoe
Default carburator rebuild?
bought a 1968 Mustang coupe with a 289 2 barrrel carb. The car was parked for about 3 years in the desert. It runs good at highway speeds but coming off a stop light and giving it a little gas it wants to "starve" for gas. If it is the carb. would a rebuild kit be in order or should I just change the whole carb. I want to leave it as a 2 barrel....no real need for a 4 barrel. thanks
Old May 25, 2006 | 10:05 AM
P Zero's Avatar
P Zero
Default RE: carburator rebuild?
ORIGINAL: dennisshoe
You got kinda a double negative there, it starves for gas yet you dont want to put on a 4bbl. What is the CFM of your 2 bbl? If its 500 you should be ok, if its any smaller than that you will run into fuel starvation problems.
-P.
Old May 25, 2006 | 06:47 PM
Color by WEASEL's Avatar
Color by WEASEL
Fuel filter first if you have not done that already. While you have it off, turn it over and check the fuel pump for a good stream.
Old May 25, 2006 | 10:00 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
I have a bunch of carb tech on my site... shameless plug....
Link in the sig
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
8lug
Sep 21, 2015 01:33 PM
