Help
Old Apr 12, 2004 | 02:57 AM
92DropTopStang's Avatar
92DropTopStang
Default Help
anyone know how to replace the universal joints on a 92 mustang????
Old Apr 12, 2004 | 03:01 AM
92DropTopStang
Default RE: Help
i really need help plz plz plz i am gonan try and change them tommorw
Old Apr 12, 2004 | 03:18 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default RE: Help
Yup.
Got a press or a vice?
If not a socket and hammer works well too.
First and obviously remove the drive shaft and remove the clips on the u joints with needle nose pliers.Then get a socket just a little smaller than the diameter and drive her out.
Some can be a pain in the ***.I have had to take a few in and be pressed out which is no big deal but most will come out.
Old Apr 12, 2004 | 03:35 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: Help
You also gotta deal with all the little splines inside the caps on the new one. Make sure you grease those up good before you put it back in.
Old Apr 12, 2004 | 05:18 AM
TheGmKiller331
I ♥ Acer
Default RE: Help
You mean the "NEEDLE BERRINGS"?
Old Apr 12, 2004 | 03:15 PM
roundman's Avatar
roundman
Default RE: Help
No, I think he means "NEEDLE BEARINGS"!
You can also use a large C-clamp and some sockets as a press to help remove the crosses from the joints. Just be real careful with the new ones so you don't disturb the needle bearings as they can be a real pain in the *** to get back in if you let them get loose in the cups. Once you got one end done, throw some duct tape around the joint to hold it together while you work on the other end and this will keep the needle bearings in their cups.
Old Apr 12, 2004 | 06:52 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Help
one very important thing it to mark your drive shaft so it is install as it came out this will eliminate any chance of a virbration accuring
