Gen TECH: Hand turning engine after storage
Old May 29, 2006 | 02:31 PM
Nunaki's Avatar
Nunaki
Default Gen TECH: Hand turning engine after storage
I have a 91 ford mustang LX with a 2.3L engine. It's been in storage for about 8 months now and I was woundering if someone could give me some advice on how to start it up safely. I have head about turning the engine a few times before actualy starting but i have no clue how to do this. I someone coiuld give me some advice on this it would be greatly appreciated.
Old May 29, 2006 | 02:53 PM
GreyStang's Avatar
GreyStang
Default RE: Gen TECH: Hand turning engine after storage
Easiest way is to take a large socket on a breaker bar & stick it to the crankshaft bolt on the front of the engine. Give that a few turns
Old May 29, 2006 | 03:41 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Pull the distributor out. Use a big drill and priming tool to prime the engine with oil. Spin the drill counter clockwise untill all the rockers have oil flowing over them. You may need to turn the engine by hand a little bit to line the lifters up with the oil holes.
OR
Pull the coil wire ( disable the ignition ) and crank it over until it has oil pressure.
Old May 29, 2006 | 04:11 PM
Color by WEASEL's Avatar
Color by WEASEL
Do both! JUST DON'T FORGET THE SOCKET WRENCH ON THE CRANK IF YOU CRANK IT OVER WITH THE STARTER! Ouch!~
Old May 29, 2006 | 05:48 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
The balancer bolt is 15/16" by the way...
Old May 31, 2006 | 03:26 PM
Nunaki's Avatar
Nunaki
Thanks everyone for your help. Nice to know some people are still willing to give a bit of advice now and then.
drfister
May 3, 2018 10:38 PM
kdryan
Aug 21, 2015 04:01 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
ccwebb
Aug 11, 2015 06:47 PM
