Tremec
Old Apr 16, 2004 | 09:39 PM
DanH's Avatar
DanH
Default Tremec
I have a tremec, but dont know what kind. How can I find that out. I want to change the fluid, but dont know what to put in it. I was told that it deppends on which trans I have. Some take this GM sincromesh or something like that, and some take ATF.
Old Apr 16, 2004 | 10:13 PM
grabbem88's Avatar
grabbem88
Default RE: Tremec
you can count your splines in the front and back shafts i think it's 33/24 they are fine splines on a tko need a c-6 yoke for it,and a centerforce or something better mcload or whatever i used mobile syncro in my tko.
Old Apr 17, 2004 | 01:23 AM
USAMuscle's Avatar
USAMuscle
Default RE: Tremec
If your car is a '90 GT, and the transmission is stock, then you have a Tremec World Class T5.
Old Apr 18, 2004 | 12:35 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Tremec
wc trans came in the cobra......not stock in a gt..they wish*L*
there is a set of number on the casing
Old Apr 18, 2004 | 08:21 PM
USAMuscle's Avatar
USAMuscle
Default RE: Tremec
ORIGINAL: vfast
How much do ya wanna bet? I'm rebuilding my dad's T5 out of his '85 GT right now and it's a WC. I have the tag to prove it. 1985 thru 1989 GTs have the same WC T5. 1990 thru 1993 GTs had higher quality gears to hold up to more torque, but still a WC. Also, the Cobra didn't come back until 1993, which actually had a T5 Z-spec 5-speed, which raised the torque capacity to 330 ft. lbs. and dropped the 1st gear ratio from 3.35 to 2.95. The non-WC transmissions were used in the '83-'84 GTs. So I don't know why the GTs would "wish" for a WC T5, because it's still a weak transmission, only capable of about 265 ft. lbs. stock. The only way to have a reliable T5 is to upgrade the gear sets to the Z-spec like the '93 Cobra had, or go all the way and order a G-force kit with 9310 gears and mainshaft and bronze shift forks which ups the power handling capability to 600 ft. lbs. of torque or 500 HP.
Old Apr 19, 2004 | 12:19 AM
Obsol3te's Avatar
Obsol3te
Default RE: Tremec
ORIGINAL: USAMuscle
ORIGINAL: vfast
Wait what?
hehe
ok what do i need to make my t5 be able to support 450+hp?
and where can i get this G force kit?
Old Apr 19, 2004 | 01:04 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: Tremec
you might be better off looking at a TKO or something like that instead of that kit. Don't know how much the kit is though so that's kinda a big factor. If it's cheap enough it might be worth the trouble.
Old Apr 20, 2004 | 04:13 PM
USAMuscle's Avatar
USAMuscle
Default RE: Tremec
http://www.5speeds.com/t5/gforce.html
The kit is $950 which contains 1st thru 3rd drive gears, the countershaft, main shaft, and stabilizer plate which works in conjunction with the countershaft. The bronze shift forks are another $250. Or you can order a complete transmission from their website for $1800. The new TKO transmissions cost about $1600, but since they are longer you would have to shorten your driveshaft or order a new one. I myself would purchase a G-force kit and upgrade the T5 because it's cheaper if you can build it yourself, which isn't really hard, as long as you have some amount of mechanical skill and a service manual which you can download from the Tremec website. The G-force T5 is rated to handle 500 HP. Any more than that you probably should think about switching to an auto.
Old Apr 20, 2004 | 05:16 PM
VertStangGT86
Default RE: Tremec
Cool, that's something to keep in mind for the future if I have any tranny problems.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Jskeezy84
Sep 8, 2015 01:40 AM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
littlehouse
Nov 14, 2004 09:20 PM
tyco
Feb 14, 2004 10:24 PM
