WIDER TIRES MEANS MORE TORQUE TO THE GROUND RIGHT?
RE: WIDER TIRES MEANS MORE TORQUE TO THE GROUND RIGHT?
you might want to look at some new rear end control arms too. they will help with the weight tranfer and plant the tires better, but you still need to lower the launch rpms to keep from spinning the tires so much, then hammer it after you get rolling.
ORIGINAL: jeep45238
Bingo. You're lucky to add 5% more traction with a wider tread of the same compound, but you can get insance increases with better compounds.
ORIGINAL: vfast
compound of tire is more important than size....
THX for the info all
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
