what should my next mod be
Old Jun 6, 2006 | 02:53 AM
Reaper's Avatar
Reaper
Default what should my next mod be
i have flowmasters, caster camber plates, eibach lowering springs, K&N air fliter,and MGW short shifter.. i have no clue what i should do next.. i want to keep it pretty cheap right now.. somewhere in the $300-$400 range.. any thoughts?!?!.. somebody said a PHP spacer?!?! or something like that?
Old Jun 6, 2006 | 11:49 AM
sandcracker21's Avatar
sandcracker21
Default RE: what should my next mod be
i take it you have the mach1?
how about a new midpipe? or gears?
you could always finish up the intake with a new tb/p combo, but i think that would be the less noticable of the three
i just mentioned
gears will give you more pop off the line, the midpipe will improve the sound and give you a moderate hp boost while makin your car a lil more efficent
Old Jun 6, 2006 | 11:53 AM
P Zero's Avatar
P Zero
Does your car have subframe connectors stock? If not get those, kenny brown makes some nice ones, super subs, they go all the way out to the pinch weld.
-P.
Old Jun 6, 2006 | 01:04 PM
NeoTokyo's Avatar
NeoTokyo
Accufab has an awesome TB out right now that can really help your car as more mods are added The part number is CTB99-01 and runs $389.99. I would also strongly suggest a C&L MAF System & Inlet Pipe (Part Number 10699PM1) It runs $369.00 and would give you a better bump at this point than the TB I believe. According to their dyno sheet the Maf Kit and Intake gave 15RWHP @4000 Peak 8RWHP @5250rpms and Torque was really impressive at 23.5RWTQ @ 4000rpms and peak was 6.5RWTQ @ 4400rpms. Its a good kit and will give you a kick in the pants at 4000rpms :P Mixed with the TB you would be doing great, the two together really arent going over your budget too much.
Other things you can look at (Not what I would do first) would be Hooker Super Comp LT Headers 3.5" Collector, 3" reducer, 3" Hi-flow cats, 3" Summit or Borla generic short X-Pipe, 3" inlet/outet mufflers of your choice dumps or take outs. (This is the reason why I would not do this one first because it requires alot more money) The headers will set you back almost $600 dollar in themselves.
You could always get a full pulley set but it really isnt as strong as a punch as a new intake/maf/tb or gears.
FRPP Gears are always a good choice and last a long time with minimal wear and are the only gears to have a bevled edge to minimize friction and failure. But they lower over overall speed and fuel economy, but you get out of the hole like a raped ape.
And of course there is always a hand held tuners, They do wonders to help the cars overall performance and remove or increase limiters. Though IMO if you are going to spend the money for a tuner then just finish all the mods that you think that you want to do then take it to a Dyno and have it Dyno Tuned, pref by Diablosport. Its a little more money but its well worth it and goes way beyond whatever the hand held could do.
Have fun.
-Eric-
Old Jun 6, 2006 | 01:08 PM
04DSGB's Avatar
04DSGB
Gears or midpipe.
Old Jun 6, 2006 | 02:07 PM
mustangman02232's Avatar
mustangman02232
4.10s and yes SFCs are stock on a mach, or atleast my buddies 04 has em
Old Jun 6, 2006 | 04:21 PM
PX429's Avatar
PX429
+1 4.10's
ORIGINAL: mustangman02232
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
