valve piston cleareance
Old Apr 25, 2004 | 12:54 AM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
Default valve piston cleareance
whats the most accurate way to check?? clay method or light spring?? light springs .151 exhast/.103 intake....clay .110 exhast/.070 intake..see what i mean???
Old Apr 25, 2004 | 01:23 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
Default RE: valve piston cleareance
THANKS FORUM PEOPLE ,,,,,,,,,FOR THE ADVICE,,,,I GUESS YOU ALL DONT CHECK YOURS...THANKS DIDNT MEAN TO BE UGLY..
Old Apr 25, 2004 | 03:49 PM
Mustang88LXKid's Avatar
Mustang88LXKid
ORIGINAL: NOS/MAN
When me and my dad checked we followed Comp Cam's directions and they said use clay form it and then put oil on it. So I would say go with the clay method because we got it right the first time.
Old Apr 25, 2004 | 04:50 PM
roundman's Avatar
roundman
NOS/MAN, see if this helps you out-from National Dragster March 26, 2004. It's the best explantion of and precise measurement of checking piston to valve clearance I've ever read!
[IMG]local://upfiles/5542/Sq462896711.jpg[/IMG]
Old Apr 25, 2004 | 06:34 PM
Mustang88LXKid
ORIGINAL: roundmanracing
thats everything you'll need for valve clearance
Old Apr 25, 2004 | 11:43 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
thanks i need to know how to blow it up it gets small in cant read it???i was just going to bring it to my machincest so he can check it he needs to install my springs anyway..hes putting the short block together for me this time because of all the notcthing and cleaning that has to be done to it...it just has .700 lift a little worried you know??408 12.5to1,,262/274@.050 .701/.686..freaking big dude..and 150 shot for now..
[IMG]local://upfiles/5822/Xu624725324.jpg[/IMG]
Old Apr 26, 2004 | 05:09 AM
roundman's Avatar
roundman
see if this is any better NOS?MAN, I ain't too good at this stuff either.
[IMG]local://upfiles/5542/Pn371257001.jpg[/IMG]
[IMG]local://upfiles/5542/Bz795150739.jpg[/IMG]
[IMG]local://upfiles/5542/Mk266488629.jpg[/IMG]
Old Apr 27, 2004 | 02:20 AM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
ill try it out thanks heres sowhen using the light spring i can hold down on the valve yill a feel it touch the piston makes the light spring go up then back down i get it to the mid point,,on check it ,,by measuring the distance between the retainers edge..im getting 2 diff readings dont know why.....i always checked the clay way ,,before,,,is that to close????also checking on my old 351w not my 408 its still in the shop..i know it wont be the same buy hoping it will be more ,,,but i thinks its going to be less because the piston will be moving faster ,,right????my piston on both motors are .010 in the hole..checking with old gasket .042 thick..with soild roller with .025 valve lash..both ways i checking over 10 times each ,,and iam going crazy not getting the same readings,,,,i know i will have to check on mt 408 ,,should i just bring the heads to the shop ,,and get them to check it also ,,they are degreeing my cam in anyway,,also my spring compressor cant compress these new springs....225 seat pressure,,,thanks for any more advice...dont want no problems with this motor..or my wife will hit me with a skillit.... .
Old Apr 27, 2004 | 02:22 AM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
dam stay big for 10 seconds than goes small
Old Apr 27, 2004 | 11:48 AM
Obsol3te's Avatar
Obsol3te
take the mouse off the picture for a second after it goes small
then place the mouse back on it
a little box should pop up in the bottom right with arrows on it
click that and itll stay big
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
