Urgent!
Old Jun 20, 2006 | 06:54 AM
sonic31's Avatar
sonic31
Default Urgent!
I just bought a 2000 GT Convertible today and it ran fine. I came home and cleaned it up for about 3 or 4 hours. I had the Radio and the like on. I turned it on twice to keep the charge but forgot for about 2 hours, I went to start it up one last time before bed and it wont start. It does not give me the regular dead battery sound though, more like a grinding noise instead of the regular engine wont turn over sound. The power top and windows are VERY slow, so im leaning on battery, but the fact that its a grindind noise makes me unsure, the alternator belts are not moving. Any help would be great, thanks!
Old Jun 20, 2006 | 10:24 AM
Chopper's Avatar
Chopper
Default RE: Urgent!
Charge the battery or get a jump start and don't let it happen again!!!
Old Jun 20, 2006 | 10:43 AM
randy78045's Avatar
randy78045
Default RE: Urgent!
Sounds like the battery, but is your starter engaging... what truly is up with that grinding noise?
Old Jun 20, 2006 | 11:19 AM
Veets44's Avatar
Veets44
Default RE: Urgent!
I have a 2000 gt convertable with 75,000 miles on it, still have the original battery with no problems. Charge it up and see if the problem goes away. If it doesn't, climb underneath and try giving the starter a whack with a hammer, it might free it up if it's stuck.
Old Jun 20, 2006 | 11:48 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Urgent!
It's prob the original battery.... It might have enough juice to start cranking the starter, but not enough to get the engine rotating and that's why you hear a grind.
I only say this because you noticed slow windows and the power top, otherwise it could be your starter has crapped out or was replaced and not shimmed properly.
Is it an auto or manual? If a new battery doesn't solve it, give the car a good rock back and forth right before you start it.
Old Jun 20, 2006 | 11:49 AM
Color by WEASEL's Avatar
Color by WEASEL
Default RE: Urgent!
It's just the battery. Jump it and move on. A car has to dun at 500 rpm just to make the alt charge enough to equal the current use. Starting it for a minute a couple times during an all day radio concert probably took more to start than you got from starting it. Mext time plug in a portable radio. And if you can't hear it like you want, get a boom box!
Old Jun 21, 2006 | 12:51 AM
foxontheprowl's Avatar
foxontheprowl
Default RE: Urgent!
with low voltage it could be the starter solenoid popping back and fourth
Old Jun 25, 2006 | 07:23 PM
jtstudley's Avatar
jtstudley
Default RE: Urgent!
get a friend to push you and bump start it.
dabsevo
Dec 16, 2013 02:12 PM
be2019
Feb 11, 2009 01:08 AM
be2019
Feb 10, 2009 12:03 PM
Car_Ramrod
Jan 2, 2007 08:19 PM
BlackGTCoupe
Apr 5, 2006 12:09 AM
