What gear ratio
Old Jul 8, 2006 | 11:01 AM
jody's Avatar
jody
Default What gear ratio
As a newbie Mustang owner, my old 87 GT has the ID tags missing that many mention about determining gear ratios, etc and the different factory options when the car was new. I was wondering what gears my car has, the seller said 3.73's but I don't think so. What should I be reading at specific speeds, at the tach? It's a five speed, so what I mean at 55mph in high gear what would it be? If I remember correctly , at 100KMph in 5th I was at around 15-1600 RPM on the tach. Thanks in advance.
Old Jul 8, 2006 | 01:17 PM
mustangman02232's Avatar
mustangman02232
Default RE: What gear ratio
2.73; 3.08; 3.27
Old Jul 8, 2006 | 01:26 PM
Colorado_Mustang's Avatar
Colorado_Mustang
100K Mph....damn, you was flyin.' [sm=icon_stickpoke.gif]
At 100 Kph (62 Mph) you should be a 1600-1700 rpm. At 55 Mph, you should be around 1500 rpm with a 3.27:1 gear. The other gears will give you a little less rpm (about 250 rpm less @ 55 for the 2.73).
Here's a helpful equation:
RPM = ((gear ratio)*(MPH)*(336)) / (tire diameter)
or
MPH = ((tire diameter)*(RPM)) / ((gear ratio)*(336))
Plus I have a little spreadsheet that does all that for ya, too...
Old Jul 8, 2006 | 08:24 PM
jody's Avatar
jody
Thanks for the replies guys, kilometers per/hr is what us what us Canadians use. I didn't think it would be 2.73, I'll do the equation to find out. Thanks again
Old Jul 8, 2006 | 10:01 PM
sprostang's Avatar
sprostang
I ♥ Acer
Jack up the car, spin the rear tire 1 revolution and count how many times the driveshaft turns. You will need to put a mark on the driveshaft. If it turns 3 3/4 turns, then you have 3.73`s
Old Jul 8, 2006 | 10:18 PM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
2.73's are GM gears. i believe. its probably 3.08's or 3.27's
Old Jul 8, 2006 | 10:26 PM
sprostang's Avatar
sprostang
I ♥ Acer
No. 2.73`s did come in mustangs.
Old Jul 8, 2006 | 10:43 PM
Jugador's Avatar
Jugador
i just bought an 8.8 rear that was supposed to have 4.10's, but by the wheel/pinion rotation test, it went a smidge over 3 1/2 so im guessing it has 3.55's. i offered him 10 bucks less and bought it anyway. thats off topic i know, so here's a gear calculator i found in the process http://www.merkurtech.com/merkurtech...ors/rpmmph.php
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
