99 GT A/C problem
Old Jul 8, 2006 | 05:33 PM
JakeC57's Avatar
JakeC57
Default 99 GT A/C problem
Any help here would be appreciated. My a/c engagement clutch cycles in and out. When disengaged the pressure reading is 46 psi. then the clutch engages and the pressure drops to 22 psi. Ok, then after it drops to 22 psi, the clutch disengages. In short: clutch engaged 22 psi, clutch disegaged, 46 psi. This cycle continues every few seconds. When, I tried to charge the darn thing, the pressure shot up to 60 psi. Of course, at that point, I aborted the whole thing.
Thanks in advance for any help understanding this whole thing.
Jake Cinzano
Old Jul 9, 2006 | 12:11 PM
JakeC57's Avatar
JakeC57
Default RE: 99 GT A/C problem
bump...
Old Jul 10, 2006 | 10:17 AM
JakeC57's Avatar
JakeC57
bump...
Old Jul 10, 2006 | 10:12 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Sounds like it's low on freon. It's dropping below the predetermined threshold and shutting the compressor off. Under charge conditions, you will see a rise in pressures from the added can of freon, after which, they will drop and stabilize. Unless you overcharge it of course.
vargas
Jun 17, 2017 12:17 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
