Gear Ratio
Old Aug 20, 2004 | 09:44 AM
  #21
Vert_Lover's Avatar
Vert_Lover
Default RE: Gear Ratio
Do you guys have any rules of thumb about HP related to gear ratio... Am I correct in assuming, the horse power your car is putting out, the higher your top end speed can be, thus the lower your revolutions at any speed relative to a car of lesser hp. In a stock mustang... you're running about 1600 rpm's in 5th at highway speeds... a little bit of work and you'll never use 5th gear for commuting. Just curious if anyone has ever run into the problem with too much power for their stock gears.
Old Aug 20, 2004 | 03:45 PM
  #22
roundman's Avatar
roundman
Vert, go back and read this whole thread a little more closely and I think you will see that your questions have been answered allready.
Old Aug 20, 2004 | 04:01 PM
  #23
Vert_Lover's Avatar
Vert_Lover
I'm getting it... with my math background you'd think I'd catch on a little quicker... at what point does traction become a problem with the gears? Obviously you'd love to have the lowest gear ratio on the back end you could if you had enough ponies up front to move that, but for practical purposes we'll never have that kind of power... alright... 373 it is
Old Aug 20, 2004 | 04:08 PM
  #24
roundman's Avatar
roundman
the traction point varies widely with the road or strip surface, the tire design, width, diameter, tire compound, inflation pressure, and how well the car transfers weight to the rear when under hard acceleration. hell, even with the stock 2.73's in an auto Fox a little moisture on the road is all you need to break traction which can make things interesting if you ain't paying attention, to to off topic and look at the 94 wreck thread if you want to see what can happen. a load of bricks in the back really helps out during the winter months!
Old Aug 20, 2004 | 04:12 PM
  #25
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
whats cheaper than $150 for a set of gears that would dramatically increase accelleration? Oh yea roundman they do make 3.90's, but FMS doesnt make them. The FMS gears are the only gears I would EVER use on an 8.8 as well...
Old Aug 20, 2004 | 04:17 PM
  #26
roundman's Avatar
roundman
you're right again MD, right after I posted that I saw that Jeg's sells a 3.89 gear for 8.8 rears too. US gears makes the gears for Strange Engineering and that's what I've got in my 9" that I bought from Strange. no complaints about them so far.
Old Aug 20, 2004 | 04:26 PM
  #27
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Not saying that other gears are inferior to the quality of FMS, just that for the average Joe like me the FMS gears are easier to install because you usually don't have to worry with pinion depth adjustment or backlash (much) when you stay in the family. If I could setup a rear-end like the pro's I'd probably have a different opinion, but I don't have the tooling to do so [&:] I can sling em in but I can't guarantee there won't be a little noise [:-]
Old Aug 20, 2004 | 04:35 PM
  #28
roundman's Avatar
roundman
yeah, what's a little noise to worry about when the driver will probably manage to wreck the car before the gears become a problem!
Old Aug 21, 2004 | 04:48 PM
  #29
jonusprime's Avatar
jonusprime
ORIGINAL: NOS/MAN
I TRYED 4,10S IN COBRA WAS TO MUCH ON LONG TRIPS ,,HAPPIER WITH 3.73S YOU STILL CAN FEEL THR DIFF,,I STILL GET 27/28 ON HIGHWAY
what does 27/28 mean?
I think you referring to gas mileage but i'm not sure.
Old Aug 21, 2004 | 05:09 PM
  #30
matthockey32's Avatar
matthockey32
I ♥ Acer
if you want to run 10s the power you will have to make will destroy the 7.5 rear end. buy a ford motorsport 8.8 loaded with 4.10s and a t-lok.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
