Need some serious help!!!
Old Jun 6, 2004 | 07:17 AM
  #21
mbliss's Avatar
mbliss
Default RE: Need some serious help!!!
Not sure if there clogged or not. I get a strong metalic smell once in awhile, almost like brakes. I unplugged the o2's and nothing. Should the two wires in the MAF glow red hot when on? Just replaced the leeky water pump also...
Old Jun 7, 2004 | 08:22 PM
  #22
roundman's Avatar
roundman
yes the wires in the MAF are supposed to be heated wires, they measure the air flow by sensing the temperature change in the wires as air flows over them. one thing you might try is disconnecting the battery negative cable for a few minutes to let the computer reset and see if this helps any.
Old Jun 7, 2004 | 08:51 PM
  #23
vfast's Avatar
vfast
I ♥ Acer
do you have a k/n filter on this car?..if so clean the maf sensor?...
Old Jun 8, 2004 | 12:55 AM
  #24
mbliss's Avatar
mbliss
No, not yet. I've cleaned the MAF already. Question is? Do the two wires glow red hot?? Could this be a leaky head gasket? It's not over heating or losing coolant? Or a bad distributor??
Old Jun 8, 2004 | 06:53 PM
  #25
vfast's Avatar
vfast
I ♥ Acer
could be a bad dist...and I do believe they get red hot(wires)
Old Jun 8, 2004 | 11:11 PM
  #26
mbliss's Avatar
mbliss
KOEO- No Codes
KOER- 13 RPM OUT OF SPECS (NORMAL CURB IDLE)
MEMORY-53 TPS TO HIGH (ADJUSTED IT TO 90)
-63 TPS TO LOW????
-66 MAF SIGNAL LOW CIRCUIT GROUND
FUEL PRESSURE 41PSI (NORMAL RANGE 35-45PSI
TPS AND MAF SENSORS ARE WORKING PROPERLY....
Old Jun 9, 2004 | 02:36 AM
  #27
04mustang's Avatar
04mustang
how do u clean the maf sensor? and how often should u do it when u have a k&n?
Old Jun 9, 2004 | 10:59 PM
  #28
mbliss's Avatar
mbliss
alcohol and a soft toothbrush, I'd do after you get your filter re-packed.
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
flash_xx
Oct 16, 2015 07:23 AM
mdj89
Oct 8, 2015 09:16 PM
mungodrums
Oct 7, 2015 04:01 AM
Sep 3, 2015 07:14 PM
