Rear end swap, need help
Old May 14, 2004 | 02:00 AM
95_GT_Stang's Avatar
95_GT_Stang
Default Rear end swap, need help
So I was involved in a little fender bender, damn women drivers. I was t-boned. She hit and bent my axle so I had to have it replaced. My original axle was taged "221C" and had 2.73 gears in it. Now my speedo is off by ten mph (so it says 50mph on my speedo when i'm only going 40). I checked the tag on the axle, and sure enough, it says "229C". I need to figure out what gears are in this axle so I can swap out the speedo gear. Any ideas?
Old May 14, 2004 | 02:24 AM
callmecobra's Avatar
callmecobra
Default RE: Rear end swap, need help
you had the 7.5 rearend, and swapped to an 8.8?
Old May 14, 2004 | 02:25 AM
95_GT_Stang
No, they're both 8.8's
Old May 14, 2004 | 01:26 PM
VertStangGT86's Avatar
VertStangGT86
Where did you get it done? Might be able to call a dealer or if you open up the rear end they might be marked. Don't know if stock ones are but a lot of aftermarket ones are.
Old May 14, 2004 | 03:32 PM
roundman's Avatar
roundman
try the ford tech line at 586-468-1356
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
