94-98 v8 questions
Old Jul 14, 2006 | 07:22 PM
rynpatosh's Avatar
rynpatosh
Default 94-98 v8 questions
i owned a 96 gt before and now i want to get another 94-98 mustang this time around i plan on adding some mods to her
im looking to get into the 12 or 11's
with this said would i be better off just starting out with a cobra because of the stonger engine
whats the cobra have that the gt doesnt
engine internals
transmission
rear end
im set on haveing a 94-98 model
thanks
Old Jul 15, 2006 | 02:24 AM
mustangman02232's Avatar
mustangman02232
Default RE: 94-98 v8 questions
94-95 = 5.0, 96-98 NPI 4.6 stock times, high 14s-low 15s
Old Jul 15, 2006 | 02:28 AM
OnyxCobra's Avatar
OnyxCobra
I could be wrong but I think the cheapest way to 12s and 11s is gonna be a 94-95 5.0. If ur gonna build it u might as well not bother buyin a Cobra unless you find one cheap b/c you'll be replacing most of the Cobra parts anyways...
Old Jul 15, 2006 | 08:15 AM
sandcracker21's Avatar
sandcracker21
the 5.0 will definatly be the fastest/easiest/cheapest route to 12.xx's
cheaper parts, a lil more response to mods then the non pi 4.6
Old Jul 16, 2006 | 12:16 AM
rynpatosh's Avatar
rynpatosh
from what i read a 96 cobra's engine is built stonger which could handle a stage 1 supercharger
Old Jul 16, 2006 | 01:53 PM
90lxstang's Avatar
90lxstang
Found this info from Stangnet:
Cast iron GT40 heads
Cast aluminum Cobra intake manifold
Crane 1.7 rocker arms
24lb fuel injectors
Cobra specific ECU (computer)
"Cobra" stamped valve covers with build sticker and signature
Engine oil cooler
Front mounted power steering fluid cooler
Lightened flywheel
Phosphate coated transmission gears
Overdriven waterpump pulley
Cobra specific camshaft
Cam specs: Duration: 227°/Intake & 270°/Exhaust
Lift: .485/.485 Intake/Exhaust
Lobe separation: 118.5°
Suspension/Brakes
13" Front brakes
11.65" rear brakes
"Cobra" embossed front calipers
Cobra specific brake booster
Cobra specific rear sway bar
Cobra specific shocks/struts/springs
K-member that is slightly stiffer than the GT's
No strut tower brace
Personally, I would get the GT. You can get them for less than half the price of the same year Cobra if you look and bargain enough, which to me, doesn't justify any additional price you would pay to get a Cobra. Unless you just really want to have a Cobra.
Going into the 12's, you wouldn't have to change nearly enough parts to make it worth the money to go ahead and get the Cobra. Again, unless you really want one. Hope this helps.
Edit: This is for 94-95 Cobras BTW. Everyone here so far, myself included, strongly suggest getting the 5.0 instead of the 4.6 for going straight to 12s.
wolverine8490
Jan 17, 2008 11:41 AM
fst100
Nov 5, 2007 09:02 AM
99v6STANG
Aug 25, 2006 02:11 AM
Autobadges.com
Aug 18, 2006 01:15 AM
planet audio
17
Jan 29, 2006 07:46 PM
