Brakes
Old May 26, 2004 | 10:24 PM
92DropTopStang's Avatar
92DropTopStang
Default RE: Brakes
I ended up getting raybestos (sp) pads and shoes and rotors
Old May 26, 2004 | 10:31 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Brakes
thats a good store brand. and so everyone knows drilled / slotted rotors may burn up pads faster, the rotors actually last alot longer and don't warp like regular ones do. I can tell you the rotors on my 02 stang only lasted 20k miles before they started shaking (were warped). Im not hard on brakes either. Got slotted ones and their gonna last near forever, and they brake ALOT better too. Can definately tell a difference (went with better pads too so coulda been atrributed to that too)
Old May 27, 2004 | 12:54 AM
92DropTopStang
Default RE: Brakes
Im just trying to spend the least amount of money and get the best braking possible beacuse I plan on doing a 5 lug conversion in a few years so its gonna get all replaced anyways. I have one more question I possibly have bad calipers any one have a sugestion on where I might get new ones?
Old May 27, 2004 | 10:57 AM
LLADNAR's Avatar
LLADNAR
Default RE: Brakes
any major parts store will carry calipers,,you will just have to give them your old one for a core because unless you ask for a true new one they will be rebuilt units
Old May 27, 2004 | 11:05 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Brakes
yep, also most parts stores carry rebuild kits (just seals etc.) for popular calipers real cheap - like those on stangs.
Old May 27, 2004 | 12:04 PM
WNDSOR's Avatar
WNDSOR
Default RE: Brakes
if you want to check into it a little bit, you can go with svo calipers, they have a bigger piston diamator and should help braking a lot. why do you think you have bad calipers?
Old May 29, 2004 | 03:49 PM
92DropTopStang
Default RE: Brakes
I think the caliper on the driver side is starting to go bad because it doesnt quite open back up all the way. I am just going to keep an eye on it and make sure it doenst get any worse and if it does ill just replace it.
Old May 29, 2004 | 03:51 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Brakes
You only need to replace a caliper if its leaking fluid or giving you uneven brake pad wear. Well, that is unless your upgrading.
Old May 30, 2004 | 12:38 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: Brakes
I'm gonna have to do at least front brakes here soon once I start getting paid at my new job for the summer.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
