ignition switch
Old May 21, 2004 | 01:37 AM
lift350's Avatar
lift350
Default ignition switch
how hard and how do you change the ignition switch in 95gt?
Old May 21, 2004 | 02:12 PM
MelloYello's Avatar
MelloYello
Default RE: ignition switch
Not too bad
Just make sure you have battery cables disconnected so that airbag doesnt send you to the back seat lol
Remove the steering column shrouds, disconnect the the wiring harness connector form your ignition switch
then if you move your ignition switch to startup position (RUN) take out the screws that hold it in there should be 2
then the switch will have an actuater pin, disconnect the pin and the swtich should pull out...
Mello
Old May 21, 2004 | 02:55 PM
lift350's Avatar
lift350
thanks for the reply and for telling me about the battery, that would be a little painfull to get hit by the airbag. about how much do they cost?
Old May 22, 2004 | 07:55 PM
MelloYello's Avatar
MelloYello
Yeah when you disconnect the battery, disconnect Negative first than positive
the switches should run you between 30 - 40 bucks
Not sure how much they run if you have pats (the ignition switch that takes a chipped key)
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
