71 Mach 1
Old Jul 21, 2006 | 07:33 PM
chuckj2's Avatar
chuckj2
Default 71 Mach 1
We just bought it, fast car, excellent motor sound.
Problem is that when we come to a stop or slow down for a corner the car shuts off.
It's a Windsor 351..with a 4Bl Holly. Anyone had the same problem? Thanks
Old Jul 21, 2006 | 07:54 PM
GreyStang's Avatar
GreyStang
Default RE: 71 Mach 1
How's the idle when it's sitting still? Is it an auto trans? Try putting it into neutral before slowing down, does it still die?
Old Jul 21, 2006 | 11:23 PM
Cobrakev's Avatar
Cobrakev
Does it sound like you are running it out of gas when it stalls? If so, check the float bowls. One of them maybe sticking or have a hole in it.
Kev
Old Jul 22, 2006 | 12:16 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
We've got a '72 Mach 1 with the 351C-4V and never had that problem.
Wish I could help, sorry....
(would you happen to have any pictures??)
Good Luck
Old Jul 22, 2006 | 04:25 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Your floats might be adjusted too high and the car ends up flooding itself out. Is it kinda hard to restart after this happens?
Old Jul 22, 2006 | 08:54 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Check your secondary float. The float sight for the secondaries is supposed to be lower than the primaries...but they get that mixed up once in a while (I had 1 shipped with 2 primary bowls, and another with the correct setup...the difference is obvious when they are side by side).
What was the original engine in that Mach?
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
