Loud single *Clank* noise when accelerating.
Old Jul 24, 2006 | 04:18 PM
Cide's Avatar
Cide
Default Loud single *Clank* noise when accelerating.
Hi all, and thanks in advance for any replies/advice.
I have a 2000 Mustang GT, 5 speed.
When I accelerate from a stop a very loud *clank* noise can be heard once, then again while accelerating after shifting into second, and sometimes into third. I can avoid the noise by accelerating extremely softly.
Any ideas on what this could possibly be?
Thanks!
James
Old Jul 24, 2006 | 04:21 PM
Du510's Avatar
Du510
Default RE: Loud single *Clank* noise when accelerating.
Is it during or after shifting?
Old Jul 24, 2006 | 04:39 PM
Cide's Avatar
Cide
After, it doesn't do it until I step on the gas pedal after shifting.
Old Jul 24, 2006 | 05:05 PM
Dan04COBRA's Avatar
Dan04COBRA
Transmission mount, u-joint...
Old Jul 24, 2006 | 05:36 PM
dirtystang04's Avatar
dirtystang04
Maybe even a motor mount also...
Old Jul 24, 2006 | 06:50 PM
Cide's Avatar
Cide
I'm not sure if this will help in narrowing it down any; but if I let off on the gas all the way and then step on it it will make the sound again.
Old Jul 24, 2006 | 07:05 PM
LTnone's Avatar
LTnone
My guess is trans or motor mount is broken
Old Jul 24, 2006 | 07:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
as mentioned above... tranny mount or u-joint. Where is the sound coming from? Under the car or in front of it? Directly under you or towards the back?
Old Jul 24, 2006 | 07:50 PM
Cide's Avatar
Cide
I'm pretty sure it's coming from under me and not from the engine - I'm not positive if it is directly under me or towards the back.
Is there anything visual I can look for under the car to check for the above problems, or should I take it to a shop and have them look?
Also, I do have a Mechanical Breakdown Protection Plan, is it possible this may be covered? All the sections say "If damaged by the failure of an internally lubricated part" so I'm inclined to think probably not, but one can hope.
Boltt's Avatar
Boltt
Best bet is to just lift the car up a little and do a quick run-through of your bolts. Last week i took mine into the shop to investigate a rumble at deceleration, and found that i had 2 U-joint bolts missing, completely. It's the little things that kill you.
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
MustangV6P
Sep 28, 2015 11:00 PM
