What needs to be changed?
Old May 25, 2004 | 12:51 AM
justpicaname's Avatar
justpicaname
Default What needs to be changed?
I just ordered subframe connectors upper & lower rear control arms, and I'm going to add a rear sway bar to my 84 2.3L. The goal is to get it ready to put a 5L over the winter, but keep driving it till then. anyways when I change I hear I may need to change 1- Rad, 2- power steering pump, 3- brakes possably, and also do I need to change to 5 bolt wheels? or will the 4 bolt hold up. Thanks
Old May 25, 2004 | 01:15 AM
SilverGTV8's Avatar
SilverGTV8
Default RE: What needs to be changed?
well the 5.0s up until 96 ran 4lugs so you should be all set there.
Yeah you are going to need a radiator, not sure on the pump though.
Old May 25, 2004 | 01:21 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
the pump goes with the motor your using, along with the alternator etc. you can try to use the stock 2 core radiator - it may very well work fine on a stock 5.0. as for the brakes and suspension - its a good idea to upgrade since the car is alot heavier now - but not a necessity. you can always get the car going with the 5.0 and upgrade what you need to when you realize it.
Old May 25, 2004 | 01:26 AM
roundman's Avatar
roundman
you will probably need to think about upgrading the tranny and the rear end as the parts for a 4 banger are weak in comparison to what they used on a 5.0.
Old May 25, 2004 | 01:35 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Ahh so true - the little 4 speed MT that came in those babies wont line up without a different pilot bearing anyways (did they put auto's on the 4cyl stangs back then?) and the rear end is a wussy 7.5". I think the rear will hold up fine under stock power as long as your not using sticky tires, but really though - I agree with roundman
Probably would be a good idea to find a boneyard 5.0 and ****** some parts on the cheap.
Old May 25, 2004 | 04:37 AM
dghost22's Avatar
dghost22
I would recommend the change to an 8.8 rear, but the 7.5 will work. the 85 gt's had the 7.5 rear and they did just fine up to a point.
Old May 25, 2004 | 08:36 AM
justpicaname
OK great , thanks guys, I'm thinking I'll pick up a 5L with a wrecked body, and take the whole drive train, and any other parts I can use. and drop them in. I guess the 5 speed tranny would have differnt mounts (maybe some welding needed?)
Old May 25, 2004 | 11:33 AM
justpicaname
oh ya I almost forgot, what about the clutch? I have no hydrolic clutch. will this work with a T5 or tremec tranny? or will I need to convert to hydrolic?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
lmurf60
Sep 24, 2015 10:07 PM
