3rd gear
Old May 25, 2004 | 02:17 AM
dustinpolcz's Avatar
dustinpolcz
Default 3rd gear
yea, my 3rd gear keeps grinding, when i'm getting off the on ramp to the interstate, racing, anything that involves shifting fast it sometimes goofs up and grinds. what's causing this? i have the clutch in like normal and everything's how it should be but it does it. not all the time but it does, does this sound like a problem or do i just need practice bc i speed shift alot and normally it works fine but sometimes it messes up.
Old May 25, 2004 | 12:25 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: 3rd gear
because these tranny's dont like to be speed shifted at all. That happens to all of us. Get a short throw and it will minumize that problem.
Old May 25, 2004 | 01:18 PM
chriscindy6369's Avatar
chriscindy6369
Your tranny is on it's way out. I blew up my 2 nd stock t-5 tranny. I just bought a TKO-500 Tremec Handles 500lbs of Torque. 3 rd gears take a beating.
Old May 25, 2004 | 01:36 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
ORIGINAL: chriscindy6369
What do one of those cost? Im thinking of looking into one myself. I've heard good things about them!
Old May 25, 2004 | 01:56 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
ORIGINAL: dustinpolcz
a shifter would help prevent mis-shifts. What you hear are the sychronizers grinding. Their job is to help the transmission speed match the engine speed. The easiest way to send them to the crapper is to miss shifts. The syncro's themselves are inexpensive, but the labor on pulling the tranny and cracking the case isnt. Maybe your just mis-shifting, maybe your not and you have syncro problems. If its the syncros then you will soon know it, as its gonna get worse each shift you grind - and your gonna have to start shifing slower and slower and at lower rpm's to keep it from grinding.
As far as putting in a TKO, the stock 3650 is rated at 375 lbs of torque (a T5 in a 5.0 is much less). A TKO is rated at 425 lbs, not a HUGE difference in itself. The big daddy TKO2 is somewhere around 475 lbs I believe. Your problem isn't that your tranny can't handle your power, its because you are mis-shifting. Besides, I wouldn't swap out the tranny anyways for just 50 lbs more handling, unless I actually BROKE something.
Old May 25, 2004 | 07:45 PM
Dan04COBRA's Avatar
Dan04COBRA
Try a short throw shifter, sometimes the trusy ol forks get bent and cause some grindage.
If not, it's time to replace!!!!!!
Old May 26, 2004 | 12:25 AM
dustinpolcz
thanks guys, i'll get a short throw. tonight i speed shifted into second and it's just straight down so it's kind of hard to mis-shift. so hopefully nothing is hurt. thanks again guys. - dustin
Old May 26, 2004 | 12:35 AM
chriscindy6369
I payed $1548.00 For Tremec -500 There brand new. They handle 500 lbs of torque. They replaced the weaker Tremec 3550.
Old May 26, 2004 | 01:01 AM
WS6speeDemon's Avatar
WS6speeDemon
3rd gear is a bitch, i used to miss it when i first got my car and grind it, but now i'm fine, EVERY ONCE IN A WHILE, I get a problem, as soon as I can I am upgrading, I suggest the same to you, missing third while racing can cost you money
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
