engine weight question
Old Jul 29, 2006 | 04:38 PM
stallion2006's Avatar
stallion2006
Default engine weight question
how much does the 4.6l gt engine weigh? and how much does the 4.0 l v6 engine weigh?
Old Jul 29, 2006 | 04:41 PM
Vash the Stampede's Avatar
Vash the Stampede
Default RE: engine weight question
both cars have 300 pounds difference from each other, and then a cobra has a 300 more pounds different then a GT.
thes are just averages. cuz that show it is on the 99-04's
V6, weighs 3,000
GT 3,300
Cobra 3,600
and then the 05+'s are a hundrund pounds or more then the current
Old Jul 29, 2006 | 04:46 PM
stallion2006
any idea what the engines weigh just by them selves?
Old Jul 29, 2006 | 05:48 PM
stallion2006
I have found part of my answere at modular depot forums. they have compiled a nifty spec sheet there that includes the weight of the 4.6l engine. its under modular engine specs incase any one has the same question.
FYI: 4.6-liter SOHC and DOHC
Aluminum block weight (bare): 86 lbs.
Iron block weight (bare): 154 lbs.
Assembled cylinder head weight: 44 lbs.*
Displacement: 4.6 liters/281 cubic inches
Bore: 3.552 inches
Stroke: 3.543 inches
Bore spacing: 3.937 inches
Main journal dia.: 2.657 inches
Rod journal dia.: 2.086 inches
Rod length: 5.933 inches
Deck height: 8.937 inches
*Assembled 302 iron head weighs approx. 55 lbs.
which means a gt's engine would weigh about 130 lbs for a alluminum engine and 209 lbs for a iron block fully assembled
Old Jul 30, 2006 | 03:00 AM
02StanGT's Avatar
02StanGT
Correct me if I'm wrong, but: 86+44+44=174 not 130, and 154+44+44=242 not 209. That's with bare blocks, which mean minus the rotating assembly.
Old Jul 30, 2006 | 10:06 PM
stallion2006
ORIGINAL: 02StanGT
my bad. so my calc would have given me the weight of a bare block + heads, darn I was starting to think I had some thing there.
classic69FB
Aug 12, 2015 11:58 PM
ccwebb
Aug 11, 2015 06:47 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
